Author Topic: RCD300 TO RCD510. CAN GATEWAY.  (Read 2554 times)
Offline Philly-GTI
« on: July 30, 2016, 08:40:03 pm »
Hello,
Currently in the process upgrading my RCD300 to a RCD510. My car is a 2007 Golf MK5 GTI.
I already have a aeriel adapted which is needed qhen ugrading to newer units but what i am unsure about is if i need to upgrade my CAN GATEWAY or not?
used my VCDS to find out what is currently fitted. Will i need to change my CAN gatway to not suffer the battery drain issues?
Address 19: CAN Gateway        Labels: 1K0-907-530-V2.clb
   Part No SW: 1K0 907 530 K    HW: 1K0 907 951
   Component: J533__Gateway   H04 0021
   Revision:   H04 02    Serial number: 010507F1001988
   Coding: 7F0F034007000001
   Shop #: WSC 01279 785 00200
   VCID: 2F6D7DC5BEAB3846D7-807A
No fault code found.
Cheers, Phil
Offline doylebros
Re: RCD300 TO RCD510. CAN GATEWAY.
« Reply #1 on: July 30, 2016, 10:10:39 pm »
L or later to have the no drain issue :happy2:
Offline Philly-GTI
« Reply #2 on: July 30, 2016, 10:22:29 pm »
Cheers for reply. so i need a gateway then? if so wheres the best place to source one?
Offline doylebros
« Reply #3 on: July 30, 2016, 10:34:18 pm »
If you want one precoded unit and sound advice so you can do the replacement yourself Eddie-NL will supply you with one.
He's a member on here he may flash your original read this http://www.mk5golfgti.co.uk/forum/index.php/topic,96401.msg957142.html#msg957142
Offline Philly-GTI
« Reply #4 on: July 30, 2016, 10:40:06 pm »
thanks for advice
4ndy
« Reply #5 on: July 31, 2016, 08:37:41 am »
Try with  the gateway "L" first as I have no drain with "K" :happy2:
Offline Philly-GTI
« Reply #6 on: July 31, 2016, 12:08:29 pm »
from what ive uploading from my vcds what gateway do i have? is mine a K?
Offline Pashka
« Reply #7 on: August 06, 2016, 08:45:11 pm »
K, with 0021 software, which is not compatible, need to change.
06 1.9 TDI Owner. Retrofits: Bixenons, Drls, Full GT/GTI exterior, RNS510+MDI+Premium Bluetooth+RVC+OPS, Full Fis, MFSW, Cruise control, TPMS, Polar Fis, Boot pop up and more.. :)
Coding, diagnostic and retrofits in Leeds
Pre coded Can Gateways for battery drain issues with RNS510 and similar headunits
Premium Bluetooth modules/kit
RNS510 Service - codes, maps/firmware updates
Latest V8 West EU maps update service for RNS315
