Author Topic: fault code p0401  (Read 792 times)
Offline bumba007
  • My Ride: mk5 tdi se 1.9 remapped
fault code p0401
« on: August 01, 2016, 10:08:20 pm »
ok ive been having this fault for sometime now and just been clearing it and after a few days it comes back. ive cleaned the egr valve out (now ordered a new one) but to no effect. ive deleted the egr valve by just removing the vacuum pipe (as told was easy way to do that) but either on or off the fault still returns. ive taken the result of the code and this is it hoping this info will help someone point me in right direction to fixing it.
calculated load value 19.2%
coolant temp 42 .c
intake manifold pressure 1.16 bar
engine rpm 1881 rpm
vehicle speed 47 km/h
intake air temp 19.c
MAF air flow 30.61 g/s
absolute throttle sensor position 99.6%
