I've owned my Mk5 for a coming up-to 7 months now and figured it was time I put up a proper progress thread.
Generic 'Home' picture..
A list of jobs soon esculated..
ECS Dogbone insert..
Once on the ramp it had become obvious there were issues with the rear brakes. The LH caliper was partly seized along with a handbrake cable that had corroded, letting water in.
So I ordered the below;
Pagid Rear Discs
Pagid Rear Pads
2 x Handbrake Cables
TRW LH Caliper
I also decided to replace the diverter valve for good measure.
A couple days later, I'd decided since I was going to be replacing all of those components, I may aswell fit a new O/S caliper that was showing its age also
March 1st - Cleaning Day.
Today was the 1st opportunity I'd had to give the car a proper clean, to which I'd only just discovered the number plates, which are not to my taste..
Out with the old
I also touched up the black rims with some cheap nail varnish - Job Jobbed.
Seat badge applied - standard.
Some clean pics prior to its cambelt, waterpump, thermostat and oil (5-40 Platinum) change at Audi on the 7th.
My Revo intake had arrived via TSR Bridgewater - Cheapest locally. (Nope, I do not use Lynx Africa.. yet
Fitted.
I'd also removed the Pre-Cat - Stolen pic below..
My Heatshield finally arrived via Midnight Garage.. Not an impressive experience.
1) Delivery time (Considering Postage Paid) was shocking.
2) The heatshield required a nice polish up due to numerous marks, scratches and glue contaminates.
Fitted;
For what it is, I would definitely suggest one of these as an additional requirement of the Revo kit.
May 2016.
Well May was going to prove an expensive month.
Firstly, I'd booked the car in at Rtec for a Stage 1 remap and wanted to prep the car with any requirements needed.
Replacement of the Cam Follower (2 years and 14k old I believe).
Not too much wear to be honest, yet I wanted to change it for my own piece of mind
I also replaced the plugs that are 23k old.
BKR7EIX Iridium plugs.
Old ones looking sh*te - Potentially a small gasket cover leak or it could be an old dropping of oil from a previous knackered PCV Valve - Will check the plugs again at somepoint.
Spark plug replacement -
Next was to finally lose the dodgy mixed budget tyres and to refurb the wheels which were not in the greatest of condition.
I'd purchased new, Genuine centre caps.. Yet the refurbing company forgot to fit them..
Hyper Silver Detroits, now wrapped with Michelin Pilot Sport 4's - Lovely rubber!
I'd also wire-wooled my tips
June 1st.
Well today was remap day at R-Tec in Hinckley, 150+ miles each way..
Pre-checks done sitting on the ramp/dyno
And so the session began.
Admittedly, I was a little nervous of a clutch taking a boot more torque yet it proved to hold out fine, even on a 340ftlb run! (Nikki later pegged this back as a recommendation).
Standard run - 210bhp & 226ftlb's.
After some fine tweaking, a few blips later, this was the final result;
One graph with the final figures of 268bhp & 303ftlb's.
Much Much Much better!
June 2016
I'd decided to start stock piling/sourcing some goodies for the Golf - I'd done alot of maintenance by this point and fancied treating it to some go-faster/shiney pieces.
After pricing up from a couple companies, I'd finally managed a reasonable deal via AKS Tuning for the following;
Superpro ALK
Superpro Wishbone Bushes
Revo Engine Mount Set
Having said that, again delivery seemed to drag on somewhat
I'd also taken a punt on some cheap Brembo/Porsche calipers that were local. It had become apparent when home that these were not suitable for the NQSBBK conversion I had planned.
Fortunately, they came with brackets.. for a Mk4
After selling the MK4 brackets on Ebay, I discussed and agree'd a deal with BrakeCaliperRefurbs to exhange the incorrect calipers for a freshly refurbed set I was after along with a Vagbremtechnic fitting kit.
Christmas in the front room...
Also, my aircon hasn't been working for a couple months (Or since I can remember needing it) so after plugging it into a generic Snap-On scanner, it suggested the pressure within the system was too high.
So it was either the pressure switch (it had one 15months ago), a wiring fault or some other s**t.
£50 punt
= Working Aircon
Sunday 31st July 2016 - Fitment of the NQSBBK, Superpro ALK, Superpro Wishbone Bushes and Revo Engine Mount Set
Prior to fitting, I'd applied some VHT paint to the centre of the discs (ideally, 7mm off centre) to help prevent getting a 'Rusty Ring'
Kit all mocked up;
I'd opted for Brembo Discs and Textar pads - This being as I like the brands and being a road car, a harder setup isn't really required for me.
All fitted;
Wishbone bushes cooking along nicely in the background
I would heavily recommend getting the tracking checked ASAP afterwards for the ALK and Bushes, this being as I had a 3 Degree discrepancy between the front wheels
So there we have my 7 month progress.. Its been expensive!
