Author Topic: Anyone changed the throttle pipe  (Read 5505 times)
Offline Madone
  • -Receive: 27
« on: August 08, 2016, 05:14:25 pm »
Do many people change the pipe that runs to the throttle body, a few people have a CTS version, is this a worthy upgrade ?
Offline Paradox1
  • -Given: 41
Re: Anyone changed the throttle pipe
« Reply #1 on: August 08, 2016, 05:19:06 pm »
if your trying to get the most from your setup then yes.
Also buy the turbo outlet replacement pipe too. the OEM one is tiny
Offline Madone
  • -Receive: 27
« Reply #2 on: August 10, 2016, 08:42:29 pm »
Who makes those pipes ?, I think forge do some ?
« Reply #3 on: August 11, 2016, 08:31:14 am »
CTS and Neuspeed make them.
Offline Dan648v
  • -Given: 28
« Reply #4 on: August 11, 2016, 08:47:17 am »
http://m.ebay.com/itm/261675948859?_mwBanner=1
Ive seen a few people use these  :happy2: not sure if you'll get hit with charges tho? Seems cheap for both pipes
Offline Madone
  • -Receive: 27
« Reply #5 on: August 11, 2016, 09:46:56 am »
Mike, did you make this upgrade ?, I saw a thread a while back where you raised the question. Not sure if you did in the end ? :smiley:
Offline Paradox1
  • -Given: 41
« Reply #6 on: August 11, 2016, 12:04:23 pm »
it basically lets the air flow quicker to the engine.
think of it like how you fit a 3inch exhaust to get the gasses out of the engine.... these pipes increase the flow into to engine
Offline Madone
  • -Receive: 27
« Reply #7 on: August 11, 2016, 12:31:30 pm »
Is it worth doing ? :smiley:
Offline Paradox1
  • -Given: 41
« Reply #8 on: August 11, 2016, 01:14:46 pm »
if you want the best out of you setup the yeah :happy2:
Offline Madone
  • -Receive: 27
« Reply #9 on: August 11, 2016, 03:09:23 pm »
Thanks mate. I see awesome have the neuspeed turbo outlet but can't see the throttle pipe ?, is the turbo one the main one ?
https://www.awesomegti.com/shop-by-car/audi/s3-8p/neuspeed-2-0t-fsi-k04-hi-flow-turbo-discharge-pipe-kit/
Offline Paradox1
  • -Given: 41
« Reply #10 on: August 11, 2016, 03:29:09 pm »
the outlet pipe you posted will only fit k04...
https://www.awesomegti.com/shop-by-brand/neuspeed/neuspeed-hi-flow-intercooler-pipe-conversion-2-0t-fsi/
this throttle pipe is for k03 by the way
Offline Madone
  • -Receive: 27
« Reply #11 on: August 11, 2016, 04:33:06 pm »
I am K04, so should be fine. Thanks
Offline Paradox1
  • -Given: 41
« Reply #12 on: August 11, 2016, 04:34:53 pm »
In that case that is the one
Offline AJP
  • -Given: 392
  • -Receive: 316
« Reply #13 on: August 11, 2016, 05:50:29 pm »
Think I'm right in saying the CTS pipes have a bigger bore than the Neuspeed ones. 2.5" rather than 2.25".
Double check that, because I'm not 100%, but it might be worth considering.
« Reply #14 on: August 11, 2016, 07:09:39 pm »
I have Neusped discharge pipe and custom AKS tuning throttle body pipe. Every little helps when making it flow & breathe better
