Below is a summary of the Manfrotto head options, i use an 804RC2 3 way head- as a rule of thumb if you are into considered compositional photography use a 3 way head. For rapid set up (action photography) then a ball and socket or Joystick ball head is better. If you do a bit of both then a ball head with separate pan locking control is a good option.
Ball and Socket Heads- perfect choice for photographers who demand rapid composition - sports, widlife, reportage etc . All the models we stock accept quick release plates where available.
MN492 Micro ball head - ideal for use on lightduty Monopods (no quick release option)
MN494RC2 Mini ball head - great for monopods / lightduty tripods uses 200PL14 release plate
MN496RC2 Compact ball head - good match to 190 series tripods and pro monopods uses 200PL14 release plate
MN498RC2 Midi ball head - good match to 190 & 055 series tripods features separate pan lock uses 200PL14 release plate
MN498RC4 Midi ball head - same as 498RC2 uses larger 410 release plate (Larger for bigger lenses / medium format
MN468MG SERIES Hydrostatic ball head for maximum lock off - for heavier loads - available with various release plate options
Joystick grip action ball heads- perfect choice for photographers who demand rapid composition - sports, widlife, reportage etc. Very quick to use - not ideal for compositional photography
MN222RC2 Best used on a monopod - not ideal when being used in the portrait aspect with heavier duty items uses 200PL14 release plate
MN322RC2 Heavier duty version of the MN222RC2 features right or left handed use, uses 200PL14 release plate
3 way heads- perfect choice for photographers who demand compositional control allows individual adjustment for each plane perfect when you have time to compose
MN056 Basic 3 way head - good positioning no quick release plate
MN460MG Lightweight head ideal for use on 190 tripods & Carbon Fibre models uses 200PL14 release plate
MN391RC2 Coventional tripod head with ability to accept small camcorder uses 200PL14 release plate
MN804RC2 Ideal standard 3 way head - good on 190 series tripods (or 055 series for taller user)
MN808RC4 Good match to 055 series tripods uses 410 release plate (Larger for bigger lenses / medium format)
3 way geared heads- perfect choice for photographers who demand precise compositional control allows fine geared individual adjustment for each plane superb for all still life applications
MN410 Good match to 190 or 055 series tripods uses 410 release plate (Larger for bigger lenses / medium format)
MN405 Good Match to 055 series tripods uses 410 release plate (Larger for bigger lenses / medium format)
MN400 Heavy duty professional geared head for use with studio legs set options
2 way heads- perfect choice for video use, spotting scopes or for smooth panning and tilting movements ie Motor sport or wildlife photography
MN128RC Popular budget smooth action head for 190 & 055 tripods uses 200PL14 release plate
MN700RC2 Ideal for lightweight video cameras on 190 series tripods uses 200PL14 release plate
MN701HDV Entry level HDV video head for 190 or 055 tripods uses 501PL release plate
MN501HDV Superb heavier duty fluid effect head for 055 series tripods (and video series) uses 501PL release plate
MN503HDV Superb heavier duty fluid head for ultra smooth panning for 055 series tripods (and video series) uses 501PL release plate
MN519 Professional heavy duty fluid head system
Panoramic Heads- Specialist heads enabling the creation of 'stitched' panoramic photographs and VR tours - best used with a levelling base MN438 or MN338
MN627 Entry level basic panoramic adaptor head
MN300N Easy to use 360 degree panoramic head
MN303PLUS Advanced 360 degree panoramic head can be used in both portrait and landscape aspect
MN303SPH As 303PLUS also enables the production of Virtual Tours by offering the ability to create 360 degree all round panoramas
Hopefully the leg and head summary is giving you a good starting point. Below are some of our most popular combinations and a suitability guide. Remember if your requirements change you can simply purchase an alternative head to suit.
190X Series combinations each kit is available with or without the dedicated Manfrotto carry case
190XPROB / 804RC2 Superb all rounder great for compositional photography and macro applications MAX LOAD 4KG max user height 5ft 10" (for comfort)
190XPROB / 496RC2 Great for rapid set ups where composition is less crucial MAX LOAD 5KG max user height 5ft 10" (for comfort)
190XPROB / 498RC2 Features larger ball head with separate pan locking control better compositional control than 496RC2 option yet still quick MAX LOAD 5KG max user height 5ft 10" (for comfort)
190XPROB / 322RC2 Super speedy set up less good for compositional photography MAX LOAD 5KG max user height 5ft 10" (for comfort)
190CXPRO3 or PRO4 / 460MG Superb lightweight kit great for compositional, travel and macro photography applications MAX LOAD 3KG max user height 5ft 10" (for comfort)
190CXPRO3 or PRO4 / 496RC2 Great for rapid set ups where composition is less crucial MAX LOAD 5KG max user height 5ft 10" (for comfort)
055X Series combinations each kit is available with or without the dedicated Manfrotto carry case
055XPROB / 804RC2 Superb all rounder great for compositional photography and macro applications MAX LOAD 4KG for users over 5ft 10"
055XPROB / 808RC4 Superb all rounder great for compositional photography and macro applications for heavier kit MAX LOAD 7KG for users over 5ft 10"
055XPROB / 498RC4 Features larger ball head with separate pan locking great all round rapid action head MAX LOAD 7KG for users over 5ft 10"
055XPROB / 322RC2 Super speedy set up less good for compositional photography MAX LOAD 5KG for users over 5ft 10"
055CXPRO3 or PRO4 / 460MG Superb tall lightweight kit great for compositional, travel and macro photography applications MAX LOAD 3KG for users over 5ft 10"
055CXPRO3 or PRO4 / 498RC4 Features larger ball head with separate pan locking great all round rapid action head MAX LOAD 7KG for users over 5ft 10"
Manfrotto produce a range of compact tripods designed for lighterweight digital equipment. These tripods are suitable for compact, bridge and some of the lightest SLR cameras and are not part of the modular system above. Therefore the heads cannot be removed. Please ensure your equipment is within the specified allowed weight.
MODO 785B Innovative grip head tripod for lightweight still and video cameras MAX LOAD 1KG
DIGI 725B Fantastic travel tripod with fitted ball head ideal for consumer SLR MAX LOAD 3.5KG
7322YSHB Ultra compact tripod with fitted ball head MAX LOAD 2KG
7322YB Larger version of the 7322YSHB with fitted ball head MAX LOAD 2KG
7321YB Compact tripod with 3 way head - also OK for camcorder MAX LOAD 2.5KG
7302YB Fantastic travel tripod with fitted ball head ideal for consumer SLR MAX LOAD 3.5KG
7301YB Fantastic travel tripod with fitted 3 way head ideal for consumer SLR MAX LOAD 3.5KG
Monopod can be an excellent alternative / complement to a tripod. Excellent when travelling light, when working space is restricted or if you want to be more discreet. Extremely good when used with image stabalized lenses. To get the most out of a monopod we would strongly recommend the purchase of either a tilt or ball and socket head.
Modo 790B Lightduty monopod ideal for compact equipment MAX LOAD 1KG
776YB Lightweight monopod for digital equipment MAX LOAD 4.5KG
679B Heavy duty professional monopod accepts additional optional heads MAX LOAD 10KG Height 156cm
680B Compact folding professional monopod accepts additional optional heads MAX LOAD 10KG Height 154cm
681B Heavier duty professional monopod accepts additional optional heads MAX LOAD 12KG Height 161cm
682B Self standing professional monopod accepts additional optional heads MAX LOAD 12KG Height 172cm
685B NEOTEC Self locking leg system rapid set up and take down accepts additional optional heads MAX LOAD 8KG Height 170cm
694CX 4 leg section Carbon Fibre lightweight professional monopod accepts additional optional heads MAX LOAD 12KG Height 172cm
695CX 5 leg section Carbon Fibre compact folding lightweight professional monopod accepts additional optional heads MAX LOAD 12KG Height 172cm
560B-1 Great for video or photographing moving subjects features integrated fluid effect ball joint for smooth panning, in built feet and fitted tilt head MAX LOAD 12KG Height 172cm
Hopefully this will help some of you to make an informed decision, HTH
![Smiley :smiley:](https://www.mk5golfgti.co.uk/forum/Smileys/newsmileys/smiley.gif)
