Author Topic: OEM boot sub  (Read 3322 times)
Offline Vithu06
OEM boot sub
« on: August 12, 2016, 06:04:15 pm »
Hey Guys, I'm looking at buying and connect a OEM audi or VW sub to MK5 in the boot where the space tyre is can someone tell me if this can be done and i'm looking at plug and play.
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Last Edit: August 12, 2016, 08:51:35 pm by r5gtt »
Offline Vithu06
Re: OEM boot sub
« Reply #2 on: August 13, 2016, 11:36:35 am »
Great thanks but I found the sub i want for a lot less i need the wires and to know if this can be done easily
Offline Vithu06
Re: OEM boot sub
« Reply #3 on: August 13, 2016, 11:36:59 am »
Has anyone done this before
MikeGolfed30
Re: OEM boot sub
« Reply #4 on: August 15, 2016, 03:19:28 pm »
 :congrats:
I am very interested in this, could it link up to my rcd500?
Offline r5gtt
  • -Given: 342
  • -Receive: 334
Re: OEM boot sub
« Reply #5 on: August 15, 2016, 06:51:45 pm »
It'll link up to your oem unit without any issues. check the link out. mk5 6 same $***  :signLOL:
Offline Vithu06
Re: OEM boot sub
« Reply #6 on: August 20, 2016, 06:03:24 pm »
Sweet do you think I can buy just the wiring harness
Offline r5gtt
  • -Given: 342
  • -Receive: 334
Re: OEM boot sub
« Reply #7 on: August 20, 2016, 06:41:36 pm »
Dealers only I'd think @Vithu06
Offline gjseb16
Re: OEM boot sub
« Reply #8 on: October 06, 2016, 08:10:57 pm »
hi
I recently did this in a mk6 golf and to be honest is so simple with a audio line out converter, which you simply splice into the the rear speaker wires there are four wires
left rear negative
left rear positive
right rear negative
right rear positive
simply cut this in half solder in the connections from audio line converter, mine came with a remote and earth and power cable as well, so then you simply splice in to power cable and earth on back off stero solder up connection plug in your rca done obviously you have to run power cable from battery obviously but it is very simply job whilst keeping completely factory look
Offline gjseb16
