Author Topic: Toureg and Q7 calipers  (Read 27144 times)
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« on: August 15, 2016, 10:45:01 pm »
Hi guys need upgrades and wondering if vw toureg and Audi Q7 calipers the same?
R5gtt
Offline r5gtt
  • -Given: 342
  • -Receive: 334
Re: Toureg and Q7 calipers
« Reply #1 on: August 16, 2016, 12:18:20 am »
Any body any body? computer says noooooooo  :sad1:
dansmith180
« Reply #2 on: August 16, 2016, 08:16:03 am »
As far as I know they're the same. I know the rears are interchangeable as I was looking at using them on mine.
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #3 on: August 16, 2016, 09:49:47 am »
Depends on the engine of the Q7. Higher powered Q7 have the same calipers as the Cayenne Turbo, the Brembo 18Z.
Lower powered Q7s and Touaregs have smaller calipers with 4 pot, that you can fit 330 mm MB discs.
Cayennes also can have Brembos 17Z that are 6 pot and you can fit with 330 mm MB discs.
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #4 on: August 16, 2016, 10:06:48 am »
oh crap they're 18 ZR so does this mean 6pot?.
I don't fancy 6 pots so maybe better off with the rear calipers off the touareg and get a fitting kit for them?.
Thanks guys  :smiley:
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #5 on: August 16, 2016, 10:35:20 am »
Not sure what's the part number. I just know them because a friend fitted them to his mk5 2.0 TDI. They might need the same adaptor kit as the Brembo 18Z:
Offline Paradox1
  • -Given: 41
« Reply #6 on: August 16, 2016, 11:11:04 am »
mate, the 4pot are fecking huuuuuge!!!
im still not sure how they will fit lol
Dont fit the rear calipers as the piston sizes are different to the front calipers even thought they are both 4 pots.
I'll try find the part numbers for you later.
Im not sure how 6 pot would fit on anything other than a bus lol
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #7 on: August 16, 2016, 11:18:23 am »
Brembos 18Z fit well under an 18'' wheel. With OZ Ultras I didn't need to use spacers. :wink:
Offline trackep
« Reply #8 on: August 16, 2016, 11:57:09 am »
That's a lovely setup Shoduchi!! whats needed to fit these? With having such a big disc do these weigh the earth like the S3 ones? How is the pedal feel? Cheers Adam
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #9 on: August 16, 2016, 12:14:51 pm »
It's all explained in my project. The 350 mm discs being a bit bigger than the R32/S3 discs are also a bit heavier (13 kg vs 12 kg). There are lighter options from ECS Tuning, for example, but I paid 100 € for both discs... They're from ATE and were quite cheap, I'd say. :grin:
The pedal feel is awesome. Do mind that my Ed. 30 came with the bigger MC (23 mm3) from factory. Earlier GTI might have the smaller MC with 22 mm3.
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #10 on: August 16, 2016, 01:17:26 pm »
I couldn't find the 4pot's on ebay and found the 6 pots which I'm thinking maybe a good buy and will cater for 350 rotors so better stopping power?. I will also need a fitting kit, rings for the oem hubs to cater for the rotors what a  :stupid: process ff*  :scared:
A bus  :driver: :signLOL:
« Last Edit: August 16, 2016, 01:22:03 pm by r5gtt »
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #11 on: August 16, 2016, 01:18:51 pm »
Sorry guys forgot to link them  :stupid:
http://m.ebay.co.uk/itm/161758632373?NAV=HOME
« Last Edit: August 16, 2016, 01:22:19 pm by r5gtt »
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #12 on: August 16, 2016, 01:19:38 pm »
Would be nice to get some numbers  :P
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #13 on: August 16, 2016, 01:20:24 pm »
Will they fit R32 18 phase 1 alloys ?.
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #14 on: August 16, 2016, 01:31:58 pm »
These are 4 pot Touareg Brembos. They look like the ones my friend fitted. They fit with 330 mm discs and you need spacers to get them under 18'' OEM wheels.
