Author Topic: Dead, all lights off on dash, then alive 5 mins later????  (Read 862 times)
Offline macarthur.2000
« on: August 19, 2016, 09:44:29 am »
2006 GTi, DSG, BWA.
after a 30 min drive, pulled into supermarket, locked up. came back to the car, unlocked it normally..........then the screen/dash died. 5 mins later, back on, drove away normally.
have VCDS, (new user) and there were no error codes other than voltage regulator error n block 61(had to update the can bus to install a RCD510)
this is the second time in a year its done this. Currently the car has no AC (pressure too low error) and the voltage regulator error I mentioned above, its also not the best starter. at work so cant post a vcds scan till I'm done.
in other post people have mentioned the low pressure fuel pump being a possible cause, or the thrust sensor  (I replaced the fuel filter a while back due to it leaking)
thanks
Offline th3_f15t
  • -Receive: 183
Re: Dead, all lights off on dash, then alive 5 mins later????
« Reply #1 on: August 19, 2016, 11:24:12 am »
Have you checked that all the fuses are secure and correct?
« Reply #2 on: August 19, 2016, 11:31:29 am »
yeah, I did have a quick scan, but will go through the box and make sure all the fuses and relays are secure.
thanks
Offline Juliand
« Reply #3 on: August 19, 2016, 11:46:46 am »
Battery connections?
