Author Topic: Best diverter valve  (Read 21340 times)
Offline probedb
Re: Best diverter valve
« Reply #30 on: December 28, 2018, 01:50:43 pm »
Can be done just with the driver's side wheel off and the wheel arch linings out. Reaching it and getting pressure onto the bolts was a bit troublesome but it got done :)
Offline Gtcpaul1971
  • Graphite blue 54 plate 5 Dr gti.
  • My Ride: Graphite blue, 54 plate gti
« Reply #31 on: January 04, 2019, 06:23:27 pm »
Had my year old rev D replaced today with the gfb dv+. The boost seemed rubbish on it so decided to try this. Seems a lot better now going by my drive back. My rev D was not broken but I have definitely noticed an improvement. So far so good 👍
Graphite blue 54 plate.
Offline slynch23
« Reply #32 on: January 05, 2019, 11:33:42 am »
If the current DV is leaking boost would I get a warning on the dash? Had my GTi 6 months now I was just wondering whether I should replace the DV or not as everyone seems to. Will I notice a difference even if the one that’s fitted is ok? It’s a 2006 model and I’ve no idea if it’s been replaced before
Offline AJP
  • -Given: 392
  • -Receive: 316
« Reply #33 on: January 05, 2019, 01:51:40 pm »
Probably not, unless it was losing so much boost it triggered a code. A DV can deteriorate over time, losing more boost as time goes on. So not only do you rarely get a fault code, it can be difficult to gauge a slow drop in boost over time from actually driving the car.
It's deemed good practice to replace the DV at service time, or perhaps every two services. At the very least it's a good idea to do a visual check of the valve from time to time (although not all DV faults can be immediately spotted by eye). Same goes for checking the cam follower too. That one is crucial.
When I test drove my GTI up I knew it was a bit down on power. Everything else about the car was perfect - big history, annual VW services etc. So I took the punt on it just needing a new DV. Few weeks later a new revision G went in, out came the old and obviously split revision C, and it felt like it'd had a mini remap! Boost restored.
Not everybody will gain that sort of power bump - there's a fair chance your DV is working fine. But it's a very good idea to get it swapped out anyway for peace of mind that you're getting full boost for the lifespan of the new DV.
