Author Topic: AJP's Build - back in love with the GTI  (Read 30132 times)
Offline Paradox1
  • -Given: 41
Re: AJP's Build - back in love with the GTI
« Reply #75 on: April 21, 2017, 10:02:19 am »
Glad to see how you're getting on with it, looks well! Be interesting to see where you go
I have a k04 on BWA at the moment which isn’t mapped yet. I was of the impression that approaching 400 ftlb is rod bending territory as well. Don’t think I’ll get close to that though off minimum 2+ hardware (k04 injectors, rs4 valve, intake, 3” decat, VIS hpfp). Would you need RFD and maybe water/meth and maybe a few other bits to get close to 400ftlb? Definitely need them to get close to 400bhp.
Try to keep it below. maybe 380tq. or less. either way the engine could go pop at standard buts less likely if you reduce the torque to be on the safe side. ahve you fitted your injectors already? Ive been told to fit injectors when you about to go for the mapping session as the fueling will be all over the place. have you logged your fuelling?
I wouldnt bother with a rfd unless (like mine) Your rf sensors are gone. water meth is a decent access if you want to push the boundaries. not essential though if he run super fuel and a decent cool. but im running it.
Offline AJP
  • -Given: 392
  • -Receive: 316
« Reply #76 on: April 21, 2017, 10:10:41 am »
Cheers mate. I've been reading up on k04 conversions, k03 hybrids etc for a while. And it'll be a while before I go down that route, if at all.
It's a funny one. Some days the car feels rapid, others it makes me want an extra 50lb/ft at high revs. Maybe depends what road I'm on, or the mood I'm in, but I seem to change my mind about it a lot.
As for BWA internals, I get the impression if torque is capped to say 350/360lb/ft there shouldn't be too much of an issue. And a sympathetic map is half the problem solved.
400lb/ft is k04 hybrid territory, or at least water-meth etc like you mentioned. It's not something I'll be trying with a BWA!
Offline Paradox1
  • -Given: 41
« Reply #77 on: April 21, 2017, 10:20:27 am »
I know the feeling pal. I was convinced my car was mapped by the previous own by how quick it would pick up. I checked the boost and it was standard 10psi. but I feel the mods ive added to it has made a difference. Can only imagine how it will feel once mapped.
Alot of it comes down to how you drive. I.E keeping the speed up and carrying the speed through the corners....at 30mph of course...
Offline AJP
  • -Given: 392
  • -Receive: 316
« Reply #78 on: April 21, 2017, 11:05:55 am »
It'll shift once you get it mapped. Are you still on the standard IC then? I'll probably pick up an alloy S3 one at some point - it should do a job for a k04 at 1.3-1.4 bar. Definitely enough for the k03 if it stays that way. Interestingly, last time I spoke to Steve at Statller he said a standard GTI IC would be fine for a k04. Maybe it would running a little less boost than a full-fat k04 setup.
While the temptation is there right now to go full steam ahead on a k04, I don't want to fall into the trap of neglecting the basics. Now it's sat how I like, and drives how I like, I'll clear the list of any little bits of maintenence, tart it up a bit, and enjoy it.
Offline Paradox1
  • -Given: 41
« Reply #79 on: April 21, 2017, 11:17:48 am »
definitely enjoy it how it is before you start buying more stuff. Thats what im doing but doing little bit at the same time.
I got full stage 2 mods. I have a wellycooler fitted to it.
I could go for a map tomorrow to be fair, but I think i'll eventually start kicking myself thinking I should have just went k04/hybrid and call it a day
« Reply #80 on: April 21, 2017, 11:48:47 am »
You two still run standard console bushes?  :stupid: :grin:
Get a TTE420  :notworthy:
All this forging stuff is a nice idea, but it's not an infallible suit of armor.  It just stops the engine from blowing quite as easily as it would with cast pistons and rods.  There is a lot of scaremongery on the TFSI tuning group from members who push things too far by running standard KO4s at 2 bar, mapped in hard cut limiters, anti-lag flames and bangs........and they wonder why they get smoke from their exhausts and break their ring lands.
You don't need to run 400lbft.  For one thing the manual box is only rated to 320lbft (by VW themselves) and secondly, sometimes less is more.  More traction!  350lbft is mechanically safer but also gives less wheelspin than 400lbft.  I've seen people blowing rear diffs on S3s on, surprise surprise, the TFSI group running that kind of torque.   So I suppose what I'm rattling on about is, yeah, get a hybrid but don't run it flat out.  Keep some headroom there. :smiley:
The TTE420 is a decent turbo but im not willing to spend the money on it tbh. there are other people who can rebuild a k04 that is a decent spec for less money. not saying more power that TTE but you get my drift.
I wouldnt want 400+ everyday, id like it keep this below the limit just incase. You alwasy hear of people getting mapped with XXX turbo then end up selling or or breaking it as it develops problems. for me I want the power(not flat out) but more so I want the reliability. All a compromise.
Like you said 350bhp/tq would put a smile on our faces, its just people get a bit greedy for power knowing you can gain more. If I can get 380ish from a rebuild k04, a TTE420 hardly seems worth the cost for an extra 40bhp
I was just being blasé about the TTE420, I know there are plenty of decent alternatives  :smiley:
I chose that turbo mainly because I got it £600 cheaper on Awesome's black Friday, and my KO4 is on it's way out.  There's a fair bit of shaft play and it's getting noisy.
It also addresses all of the standard KO4's shortcomings (surging, crap bearings, limited top end etc) whilst spooling just as early and being built to run those kind of shaft speeds.  Given a standard turbo is £1000+VAT from VW, £1500 for a 420 is comparatively good value for such a big upgrade, both in terms of build quality and flow.  Well, that's how I justify the expense to myself at least  :grin:
I certainly wouldn't pay the full £2K+ whack for one.  I'm with you there.
Yeah I am always suspicious of people spending £1000s on big upgrades and then selling the car a week after completion.  What are they not telling us?
I hear that a lot.  "What's the point of a TTE420 when a KO4 can do 380-400?".  Similarly, why did VW bother with a KO4 on the Edition 30 to make 30hp more than the GTI?  It's the garden hose vs fire truck hose flow analogy again.  It's all about flow.
Those bigger turbine/compressor wheels kick like a mule, and I would rather make 380hp from less pressure, which doesn't heat the intercooler up as much and is friendlier to the engine.  Again, less is more  :happy2:
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #81 on: April 21, 2017, 12:07:21 pm »
It's a little crazy people wanting to go TTE420 when a K04 can reach 380 and hold its own plus wmi will add a few horses to this for a lot less than what you'd be spending on a tte and forging imho.
@Paradox1 hurry the heck up and go hybrid you indecisive you  :signLOL: why you pussy footing around  :thinking:
Sorry @AJP but someone has to tell him  :grin:
Offline Pesky jones
« Reply #82 on: April 21, 2017, 01:06:07 pm »
Its still running k03 injectors. If I put my foot down as is, the engine runs very lean and could melt pistons. The k04 2+ fuelling hardware (injectors, RS4 FPV, 200bar sensor) needs to go in accompanied by a new map at the same time. So im going to install the hardware and send the ECU to nikki for a base map which will run the engine on low but safe boost.
I have done some logging which shows it is only asking for the k03 fuelling pressure of 110bar. Which suggests the map isn’t even asking for any fuel for the K04. Also boosting to high heaven as I only have a 2.5 bar MAP sensor installed (do have the 3.5 sensor ready for the base map). The boost graph looks like a flat top pyramid – there is a whole peak of “unknown” boost I cant see as the sensor cant read it.
I agree with the last two paragraphs of Puddings last post.
R5 calling someone indecisive  :doh:
Offline Paradox1
  • -Given: 41
« Reply #83 on: April 21, 2017, 01:14:51 pm »
@r5gtt  - I will. just need to find someone to weld the turbo housing for me. Im not paying stupid money fot 10mins work
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #84 on: April 21, 2017, 01:55:36 pm »
private joke  :fighting2:
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #85 on: April 21, 2017, 01:57:08 pm »
ano bro some people hey  :stupid:  :signLOL:
Offline Paradox1
  • -Given: 41
« Reply #86 on: April 21, 2017, 02:06:39 pm »
I can tell yopu've done your homework on this.
You got me thinking now. im not sure if I need a 3bar Map sensor for mine or if I already have one fitted. will have to do some research.
 :thinking: :thinking:
Offline Pesky jones
« Reply #87 on: April 21, 2017, 02:48:55 pm »
K03 MAP sensor revision is B and D I believe. K04 revision is C. Quite fiddly but shouldn't take long to check - about half way up the charge pipe. K03 sensor will read up to 2580mbar IIRC so if your boost reaches that, then flatlines at 2580mbar then you have k03 MAP. If it goes past that then you have K04 MAP sensor. Obviously you need to be running above 2580mbar (22psi after atmospheric) in the first place. Probably quicker and easier just to check the part number  :laugh:
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #88 on: April 21, 2017, 11:54:41 pm »
Check PN after that essay  :phew:  :signLOL:
Offline MIJ_JAGGER
  • -Given: 103
  • -Receive: 78
« Reply #89 on: April 22, 2017, 12:43:59 pm »
Great thread matey the ed30 lights do transform the rear, they look better on red cars I think
