Author Topic: Superchips Bluefin  (Read 9245 times)
Offline AJP
  • -Given: 392
  • -Receive: 316
Re: Superchips Bluefin
« Reply #15 on: August 29, 2016, 06:03:45 pm »
I have super chips bluefin 290 on rolling road edition 30 but I'm happy with it.its faultless in my eyes and you can switch back to original or upgrade to stage 2 for £50.but I agree r tech will get more power but with higher boost etc.
R-Tech get more power, with LESS boost. Which is kind of the point being made.
Offline 993BOY
  • -Given: 18
« Reply #16 on: August 29, 2016, 06:21:13 pm »
So are we saying that a stg 1 remap on an ED30 using Bluefin can be damaging to engine/turbo/clutch etc?
Or, stages of tune over stg 1 can damage??
Offline Aidy06
« Reply #17 on: August 29, 2016, 07:56:38 pm »
Can you sell on the Bluefin devices or not? I've got one sat in my loft but assumed that they locked to one car.
Offline 993BOY
  • -Given: 18
« Reply #18 on: August 29, 2016, 08:17:29 pm »
I was also wondering the same thing, but guessing that they lock onto the chassis number when reading the ECU??
nkp
« Reply #19 on: August 29, 2016, 08:22:54 pm »
Once you've used the bluefin on your vehicle it can be reused again, but it needs to go back to super chips for them to reset it - costs about 250+.
Offline Madone
  • -Receive: 27
« Reply #20 on: August 29, 2016, 08:25:19 pm »
I had bluefin at stages 1,2 and 3. If anything they would be less damaging at the higher stages as those seem to be even further behind the other tuners. Stage 1 bluefin was the best, 2 and 3 didn't add much. Going from bluefin stage 3 to Revo stage 2+ was night and day. bluefin stage 1 is fine, if you have it already don't worry and just enjoy the car. If you want to go past stage 1 then another tuner would be better.
Offline 993BOY
  • -Given: 18
« Reply #21 on: August 29, 2016, 08:36:03 pm »
That is the basis that I worked on when I bought it, cheap easy tune for a massive performance improvement, plus easy to remove if required  :happy2:
If it is a safe tune, all the better  :smiley:
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #22 on: August 29, 2016, 09:41:38 pm »
Have a read of this: http://www.mk5golfgti.co.uk/forum/index.php/topic,65077.0.html
Bluefin after 1.7 bar of boost. R-Tech only need 1.3bar for a better performance.
Bluefin asking far too much of the stock hardware in that setup - hardly a safe setup long term
« Last Edit: August 29, 2016, 09:43:38 pm by GrayMK5GTI »
Offline bonelorry
  • -Given: 72
  • -Receive: 44
« Reply #23 on: August 29, 2016, 10:56:39 pm »
My friend had a Bluefin on his MK5 Golf GT TDI 4Motion, He really rated and to be fair to Superchips he ended up with about 5-6 different maps from them as they tailored it to suit his needs.
I.E At first it was a bit smokey so they altered the software a few times and sent it back to him FOC.
I would always go for a proper bespoke map myself though, My ED30 will be going to R-Tech for a Stage 1. I have used them twice before on previous cars and have nothing but praise for them.
Offline Beddie
  • -Receive: 76
« Reply #24 on: August 29, 2016, 11:08:32 pm »
In the interest of balance i ran Superchips Bluefin (stage1) on my ed30 for 80k without a single issue  :happy2:
Not just road miles either, LOTS of hard track miles and it always pulled well and didn't miss a beat, swapped the Bluefin onto my ed35 and did 40k in that in a similar trouble free manner  :happy2:
I've no doubt R-Tech/Revo etc offer a better mapping solution and greater numbers, but for the money and the convenience i honestly couldn't fault the Bluefin..
Carbon Grey Edition 35 - Here
Offline Madone
  • -Receive: 27
« Reply #25 on: August 30, 2016, 09:54:06 am »
My bluefin stage 1 map peaked at 1.4 bar, not sure what was happening with the 1.7 reading !, sounds odd.
Offline john87
  • -Receive: 53
« Reply #26 on: August 30, 2016, 12:30:30 pm »
I had bluefin stage 1 on my mk6 R, I found it made the accelerator pedal far too sensitive (was quite difficult maintaing 20/30mph without going on/off) and wave of torque came in too quickly which made the clutch slip @23k miles. On this basis I wouldn't recommend.
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #27 on: August 31, 2016, 08:32:20 pm »
It's stage 2, that's why boost is higher  :happy2:
Offline unzippy
« Reply #28 on: September 01, 2016, 02:48:05 pm »
Anything that makes the engine work harder will increase wear to all components.
« Reply #29 on: September 01, 2016, 07:53:59 pm »
I have logs from Bluefin stage 1, 2 and 3 and peak is always 1.3/1.4bar.  :smiley:
