Author Topic: ttrs brakes on mk5?  (Read 6058 times)
Offline r5gtt
  • -Given: 342
  • -Receive: 334
ttrs brakes on mk5?
« on: August 29, 2016, 03:40:34 pm »
Will ttrs brakes fit my mk5
« Last Edit: August 29, 2016, 03:43:36 pm by r5gtt »
Offline bbfb10
Re: ttrs brakes on mk5?
« Reply #1 on: August 29, 2016, 03:54:34 pm »
Yes. You may need a spacer depending on your wheels.
I have them on my GTI
Full VCDS Hex + Can.
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #2 on: August 29, 2016, 03:57:22 pm »
thanks @bbfb10 I've got some 15mm spacers coming in x4 so hopefully get these this evening with discs and lines.
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #3 on: August 29, 2016, 04:00:39 pm »
Anything look odd about this
Offline bbfb10
« Reply #4 on: August 29, 2016, 04:00:59 pm »
What wheels and discs are you running?
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #5 on: August 29, 2016, 04:21:22 pm »
R32 18" wheels. not sure on discs yet so any help would be greatful. :smiley:
I'm running oem ones at present.
are they direct fit and no brackets needed?.
« Last Edit: August 29, 2016, 04:25:15 pm by r5gtt »
Offline AJP
  • -Given: 392
  • -Receive: 316
« Reply #6 on: August 29, 2016, 04:32:49 pm »
You can fit the calipers with oem TTRS discs (370mm) but those discs get slated. Apparently they warp really easily. There are loads of threads on this.
The most popular option is to use the 340mm TTS disc. However, you will need adapters. AKS sell them, I think they're around 200 quid. Again, lots of threads covering it.
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #7 on: August 29, 2016, 05:08:59 pm »
I was just told about the discs by paradox re warping.
£200 for adapters like wt*  :surprised: almost the same cost as the discs.
Thanks AJP
Offline AJP
  • -Given: 392
  • -Receive: 316
« Reply #8 on: August 29, 2016, 05:16:22 pm »
Thanks AJP
Yeah it aint cheap is it. I looked at TTRS as well as the 18z option, and as good as they both undoubtedly are, it's a big chunk of money. I don't know if anyone else makes the brackets (or how good they are). Once in a while you see the AKS brackets coming up 2nd hand, but it's rare.
If there was a good aftermarket replacement for the 370mm disc you'd be laughing. But as far as I know the only thing available is an expensive two piece, like the 362mm disc that forms part of the 2 grand AKS TTRS kit! The kit with adapters and 340s is 1200 quid if I remember right.
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #9 on: August 29, 2016, 07:08:57 pm »
I found some adaptors for £120 so should be okay as I've used the similar on my brembo LCR for the tt and they were fine. I think I'll go smaller discs as per recommendations
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #10 on: August 29, 2016, 07:21:40 pm »
sitting in the boot right now  :jumping:
Offline Johnsy
« Reply #11 on: August 29, 2016, 07:26:20 pm »
I don't think they warp, I don't think it's possible to warp cast iron, it's more the standard TTRS discs are both the same hand/directional vanes so one side runs hotter than the other.which isn't ideal when pushing on, you'd probably never notice in a mk5 gti unless you track it.
The vagbremtechnic carriers that allow use of the 340mm TTS disc may seem a tad expensive but the TTS discs can be had for about £80 ( Brembo) a pair where as the the TTRS are north of £300.
I bought my kit bit by bit ,and I was lucky to find the vagbrem carriers and j-hooked discs lightly used locally on eBay for about £120 ( Bargain ) the seller thought they where warped after a trip to the ring,but what he was experiencing was probably pad deposits because Iv never any problems with them,
great upgrade
Offline Johnsy
« Reply #12 on: August 29, 2016, 07:30:18 pm »
Not scare mongering but there are some pictures of the cheaper carriers bent/distorted some where . The vagbremtechnic jobbies are like £250 but atleast you get a quality product and HEL hoses are included which are £40-£50
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #13 on: August 29, 2016, 11:00:57 pm »
batt 1% I'm eating out with family :smiley:
Offline Johnsy
« Reply #14 on: August 29, 2016, 11:40:03 pm »
Tut tut , it's a school night
