Author Topic: Thermostat Replacement  (Read 911 times)
Offline Sheeny94
« on: August 29, 2016, 05:45:03 pm »
Going to be changing my thermostat in a couple of days (deep joy haha)
I've seen the pelican parts diy guide and doesn't look too bad just time consuming really
Just wondered if anyone out there that had tackled the job had any tips for the task?
Thanks in advance :)
Offline OEM+ DUB
Re: Thermostat Replacement
« Reply #1 on: August 29, 2016, 09:46:19 pm »
Hi there
I did mine (and the two inline units - 05 DSG) on the drive at home and like you say, it's relatively straightforward as long as you are methodical.  There is a lot of disassembly so I laid everything out in a logical order as I took it off.  The alternator is a tight fit in the mounting so lever out with a big screwdriver or crowbar and lube before refitting to make it a bit easier.  I used ramps to elevate the front of the car and these were fine for the job.
I also changed the auxiliary drive belt as a precautionary measure whilst it was stripped down.
Hope this helps and good luck!
OEM+ 2005 GTI DSG (high factory standard spec and upgraded with S3 alloy hubs, S3 alloy wishbones, Bilstein B8s and VWR springs by my own hands) owned since 2008 and still loving it!
Offline Sheeny94
« Reply #2 on: August 30, 2016, 10:15:49 am »
Hi there
Thanks for the info mate think I'll change the belt while it's off too
