Author Topic: Car turned on with dashboard airbag sensor unplugged  (Read 1532 times)
grayzee
« on: August 30, 2016, 10:12:35 pm »
Hey all,
I turned my car on without plugging in my airbag light sensor back into the dashboard. (was wiring in my sub)
My airbag light now remains on when I turn my car on. I know its not a fault cos its triggered by me unplugging the sensor.
My mate had this Maxiscan MS509 image below so we did a scan and no codes came up or got flagged. We tried the clear memory option and everything. But the light remains on? Should I try buying the VW scanner this guy uses in the following video? Think he is using the U281 OBD scanner linked below.
https://www.amazon.co.uk/U281-OBD-2-CAN-BUS-SCANNER-SKODA/dp/B001C9V89A/ref=cm_cr_arp_d_product_top?ie=UTF8
 https://www.google.co.uk/url?sa=i&rct=j&q=&esrc=s&source=images&cd=&ved=0ahUKEwjw2vrP_-nOAhXB1xQKHXSTCFsQjBwIBA&url=http%3A%2F%2Fwww.ecutool.com%2Fproimg%2FOBDII_EOBD_SCANNER_MaxiScan_MS509_3534003_a.jpg&psig=AFQjCNGjFVlMvZe_sSjXL3IAdNpMVg_VNA&ust=1472675964067133
Any help on this would be greatly appreciated.
G
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
Re: Car turned on with dashboard airbag sensor unplugged
« Reply #1 on: August 31, 2016, 07:28:07 am »
Most scan tools only pick up engine OBD2 codes, nothing manufacturer specific or for any other systems such as ABS, airbags etc.
Find someone with a VW specific tool such as VCDS and ask them to clear the code. Will take about a minute to do
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
« Reply #2 on: August 31, 2016, 10:34:05 am »
This...
Or the carista app with an obd can clear airbag codes.
