Author Topic: Abs g201 fault  (Read 1511 times)
Offline leericho
Abs g201 fault
« on: September 01, 2016, 02:12:06 pm »
Had a bit of search thru the forum, sounds like my pump is goosed.
Where's the best place to find a replacement/ repair kit.?
Going to double check it definitely goosed by hooking up vagcom and seeing what pressure its reading
Any help will be much apreciated
Offline AJG09
  • -Receive: 21
  • My Ride: 2005 mk5 golf 1.6 FSI
Re: Abs g201 fault
« Reply #1 on: September 01, 2016, 03:16:34 pm »
I had issues with my abs earlier in the year and was told by 2 garages it was my pump. I decided to look at the fuses for the abs (2 green ones top right of the engine fuse box from memory) and one of the fuses had like a bubbling/corrosion patch on one of the blades. Changed it and fixed it. Only cost me £3. Gotta be worth checking.
I uploaded a picture of my fuse on here on another thread, try searching as youll see what i mean. The fuse itself wasnt blown!  :smiley:
Offline AJG09
  • -Receive: 21
Re: Abs g201 fault
« Reply #2 on: September 01, 2016, 03:24:54 pm »
Offline leericho
Re: Abs g201 fault
« Reply #3 on: September 01, 2016, 08:05:30 pm »
Cheers, worth a look
