Author Topic: MFD2 iPhone uses  (Read 1517 times)
Offline BenJeffrey
MFD2 iPhone uses
« on: September 03, 2016, 05:33:32 pm »
Evening all,
I can't seem to find anything in search (probably can't use the function properly) but needing some guidance.
Car came with MFD2 and there is an older style 30 pin iPhone cable coming from behind the headunit, providing the AUX and charging facility for the phone. From this cable, can you also play video into the headunit? I've tried but no luck, just producing a blank screen.
Just to add, i'm using a 30 pin to lightning adapter for my iPhone 5s, could this be the issue and I need a newer VW cable?
Cheers  :happy2:
Offline Pashka
Re: MFD2 iPhone uses
« Reply #1 on: September 03, 2016, 10:30:00 pm »
Evening all,
Cheers  :happy2:
Not possible.
06 1.9 TDI Owner. Retrofits: Bixenons, Drls, Full GT/GTI exterior, RNS510+MDI+Premium Bluetooth+RVC+OPS, Full Fis, MFSW, Cruise control, TPMS, Polar Fis, Boot pop up and more.. :)
Coding, diagnostic and retrofits in Leeds
Pre coded Can Gateways for battery drain issues with RNS510 and similar headunits
Premium Bluetooth modules/kit
RNS510 Service - codes, maps/firmware updates
Latest V8 West EU maps update service for RNS315
