Author Topic: Cruise Control HELP  (Read 6329 times)
Offline r5gtt
  • -Given: 342
  • -Receive: 334
Re: Cruise Control HELP
« Reply #15 on: September 25, 2016, 09:31:15 pm »
 Hi @Eddie-NL
Sunday,25,September,2016,11:02:56:53046
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 14.10.0.0
Data version: 20141022
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: Sporadic communication error 1000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine        Labels: 06F-907-115-AXX.lbl
   Part No SW: 1K0 907 115 J    HW: 1K0 907 115 F
   Component: 2.0l R4/4V TFSI     0030
   Revision: --H10---    Serial number: VWZ7Z0E2853031
   Coding: 040300031C070160
   Shop #: WSC 00325 210 89095
   VCID: 2D577F73B4DE0849F4D-8078
No fault code found.
Readiness: 0110 0101
Address 02: Auto Trans        Labels: 02E-927-770.lbl
   Part No SW: 02E 300 043 C    HW: 02E 927 770 AE
   Component: GSG DSG         070 1111
   Revision: 04507000    Serial number: 00000510130120
   Coding: 0000020
   Shop #: WSC 01279 785 00200
   VCID: 1421CA9737B4B981DB3-8041
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl
   Part No SW: 1K0 907 379 AA    HW: 1K0 907 379 AA
   Component: ESP FRONT MK60      0102
   Revision: 00H13001
   Coding: 0004738
   VCID: 71EFA30368662CA9905-8024
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No: 1K0 907 044 BE
   Component: ClimatronicPQ35 090 0808
   Shop #: WSC 00000 000 00000
   VCID: 6BD3B16B4A4AC679AA9-803E
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 3C0 937 049 E    HW: 3C0 937 049 E
   Component: Bordnetz-SG     H37 1002
   Revision: 00H37000    Serial number: 00000005171020
   Coding: 258DC8130004182828140028140014001408110032
   Shop #: WSC 12345 785 00200
   VCID: 2B53716B8ACA0679EA9-807E
   Subsystem 1 - Part No: 1K2 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer VW350  013  0402
   Coding: 00065493
   Shop #: WSC 12345
6 Faults Found:
01834 - Bulb for Side-Blinkers; Left (M18)
            012 - Electrical Fault in Circuit
             Freeze Frame:
                    Fault Status: 01101100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 235
                    Mileage: 126429 km
                    Time Indication: 0
             Freeze Frame:
                        OFF
                    Voltage: 12.30 V
                        OFF
                        ON
                        OFF
                        OFF
                        OFF
01835 - Bulb for Side-Blinkers; Right (M19)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 235
                    Mileage: 126429 km
                    Time Indication: 0
             Freeze Frame:
                        OFF
                    Voltage: 12.35 V
                        OFF
                        ON
                        OFF
                        OFF
                        OFF
00988 - Lamp for Brake Light; Right (M10)
            012 - Electrical Fault in Circuit - Intermittent
             Freeze Frame:
                    Fault Status: 00101100
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 20
                    Mileage: 126558 km
                    Time Indication: 0
             Freeze Frame:
                        OFF
                    Voltage: 11.85 V
                        OFF
                        ON
                        OFF
                        OFF
                        OFF
00984 - Left Tail Light (M4)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 26
                    Reset counter: 235
                    Mileage: 126429 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 13.30 V
                        ON
                        ON
                        OFF
                        OFF
                        ON
00985 - Right Tail Light (M2)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 6
                    Reset counter: 235
                    Mileage: 126558 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 11.90 V
                        ON
                        ON
                        OFF
                        OFF
                        ON
01519 - Bulb for Back-Up Lights; Right (M17)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 235
                    Mileage: 126429 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 13.45 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 N    HW: 1K0 909 605 N
   Component: 2F AIRBAG VW8   015 2100
   Revision: 03015000    Serial number: 0038ED0P0WW+
   Coding: 0012870
   Shop #: WSC 01269 785 00200
   VCID: 377B5D1B4682B2999E1-8062
   Subsystem 1 - Serial number: 6332MSME0C7D1D68V
   Subsystem 2 - Serial number: 6342MSME0C7F3906O
   Subsystem 3 - Serial number: 6352QSME054D1D37N
   Subsystem 4 - Serial number: 6362QSME04322505%
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 AG    HW: 1K0 953 549 AG
   Component: J0527           034 0070
   Coding: 0012142
   VCID: 77FB9D1B060272995E1-8022
   Subsystem 1 - Part No: XXXXXXXXXXX
   Component: E0221           007 0050
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No SW: 1K8 920 970 F    HW: 1K8 920 970 F
   Component: KOMBIINSTRUMENT VDD 2444
   Revision: V0003000    Serial number: VWZ7Z0E2853031
   Coding: 0033403
   Shop #: WSC 02700 210 91099
   VCID: 356757135C8E40898CD-8060
Address 19: CAN Gateway        Labels: 1K0-907-530-V1.clb
   Part No SW: 1K0 907 530 F    HW: 1K0 907 951
   Component: Gateway         H10 0120
   Revision:   H10       Serial number: 2800105A2505C4
   Coding: 3F3F0340070003
   VCID: 2A5D746F85301F7111F-807F
2 Faults Found:
00381 - Databus Instrument Cluster
            004 - No Signal/Communication - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 1
                    Fault Frequency: 17
                    Reset counter: 6
                    Time Indication: 15
00474 - Control Module for Immobilizer
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 6
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 00:01:28
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO            VDD 2444
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN2.lbl
   Part No: 1K0 959 701 K
   Component: Tuer-SG         024 2388
   Coding: 0000692
   VCID: 3665501F41884B91857-8063
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K2 909 144 K
   Component: EPS_ZFLS Kl.5   D06 1701
   VCID: 34616A1757F45981BB3-8061
Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 AK
   Component:    KSG              0401
   Coding: 19C802087F3D0E0FC85FEED010CC
   VCID: 79FF9B23301664E9285-802C
   Subsystem 1 - Component:   Sounder No Answer
   Subsystem 2 - Component:       NGS No Answer
   Subsystem 3 - Component:      IRUE No Answer
3 Faults Found:
01135 - Interior Monitoring Sensors
00323 - Vehicle Inclination Sensor (G384)
01134 - Alarm Horn (H12)
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN2.lbl
   Part No: 1K0 959 702 K
   Coding: 0000692
Address 56: Radio        Labels: 1K0-035-1xx-56.lbl
   Part No: 1K0 035 186 P
   Component: Radio BVX       016 0023
   Coding: 0040402
   VCID: 3363690B52FA5EB9A29-8066
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN2.lbl
   Part No: 1K0 959 703 F
   Component: Tuer-SG         021 2429
   Coding: 0000144
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN2.lbl
   Part No: 1K0 959 704 F
   Coding: 0000144
End-------------------------(Elapsed Time: 02:32)--------------------------
« Last Edit: September 25, 2016, 09:48:19 pm by r5gtt »
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #16 on: September 26, 2016, 10:16:10 am »
can't see anything wrong
check measuring values in the ecu for brake pedal and stalk switch
Cluster and Key coding
Location Great Yarmouth
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #17 on: September 26, 2016, 12:13:59 pm »
I'll have a look but can you point me to the correct measure blocks please?.
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #18 on: September 27, 2016, 11:59:46 am »
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #19 on: September 27, 2016, 12:12:10 pm »
@r5gtt Looks like your fuse for alarm is also out and a bunch of bulbs not working too
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #20 on: September 27, 2016, 12:23:47 pm »
Bulbs are all okay as ive done the double brake and side light mod and alarm I bought off here worked for a week and failed lol
I'll have a look but this has happened after the clock change   :doh: :thinking:
« Last Edit: September 28, 2016, 10:42:28 pm by r5gtt »
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #21 on: September 28, 2016, 10:45:05 pm »
http://wiki.ross-tech.com/wiki/index.php/Checking_Cruise_Control_using_Measuring_Values
Thanks @Eddie-NL I looked it up and can't seem to get into that anymore as login coding doesn't highlight  :thinking: I recall when @RetroRaz told me how to do it worked that time but now it's not going in.
Offline mikezs
« Reply #22 on: October 01, 2016, 12:40:41 pm »
Did you code your engine as well as your steering wheel controller?
