Author Topic: Which rear ARB size???  (Read 2297 times)
Offline graham-gti
« on: September 08, 2016, 02:59:54 pm »
Hey guys as the title suggests, which size whiteline rear anti roll bar do I go for?? 22mm or 24mm???
Any differences in the 2 in regards to performance
Many thanks
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
Re: Which rear ARB size???
« Reply #1 on: September 08, 2016, 04:01:02 pm »
Why not H&R that has teflon covering the bushes so they don't squeak?
I'd say 24 mm, if you want a RARB.
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
  • K04 PLAY....ZOOM DIS!
« Reply #2 on: September 08, 2016, 04:31:50 pm »
I ran just the rear for about 2 yrs...it was an H&R 24mm set to its stiffest position...was fine for eliminating understeer but the body roll, slight as it was, was still there so I added a front as well. I think a 24mm will suit you just fine as should a 22mm being that most brands are adjustable. If you are looking for serious change...go 24mm and play with the adjustments...and then a front ARB when you determine flatter is better for aggressive cornering should your dampers and tires also be up to the task.
Offline graham-gti
« Reply #3 on: September 08, 2016, 04:44:36 pm »
Wicked thanks guys
Offline Paradox1
  • -Given: 41
« Reply #4 on: September 08, 2016, 04:56:43 pm »
Having just the rear roll bar fitted, didnt that make the back end more snappy? especially on the hardest setting.
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #5 on: September 08, 2016, 05:23:50 pm »
I think it's better to have a front and rear upgraded kit. But if the option is to do the upgrade by steps, I'd get the RARB first with 24 mm. I'm still not 100% sure if I keep mine with 22 mm in the stiffest position or if I end up upgrading to a 24 mm.
Offline graham-gti
« Reply #6 on: September 08, 2016, 06:52:24 pm »
Cheers again guys. What drop links are you guys using if you don't mind me asking
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #7 on: September 08, 2016, 07:39:45 pm »
OEM drop links are fine with H&R -30 mm springs that I have fitted.
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
« Reply #8 on: September 09, 2016, 03:30:41 am »
Definitely...I lost the back end a couple times...but without the front, it felt like the body was under an extreme amount of axial torque, front to back, when pushed hard...like wringing out a wet cloth. Front end would lift and it felt like it was trying to snap about its midriff when pushed hard through the curves. Front ARB fixed it so that it remains flat and didn't transmit that feel...entry speed is more than I expect it can be and you can push it throughout.
I've always had the oem links and they have performed without one snapping to date...so I would replace with oem if one eventually does.
« Last Edit: September 09, 2016, 03:37:56 am by ROH ECHT »
Offline graham-gti
« Reply #9 on: September 09, 2016, 07:38:54 am »
Thanks again guys massive help as always
