Author Topic: Weird knocking noise  (Read 1458 times)
Offline DomBacon
« on: September 09, 2016, 10:57:10 pm »
I have a bit of a weird knocking noise after I come off the accelerater. Does it at low, medium and high speeds.
Recently changed my engine mounts and fitted a dog bone insert mount and still does it.
Can't think what it could be and its driving me insane  :signLOL:
Anyone know what it could be?
Thanks Dom.
« Last Edit: September 10, 2016, 02:59:03 pm by DomBacon »
Offline Craig Stanley
Re: Weird tapping noise
« Reply #1 on: September 10, 2016, 10:25:06 am »
I had a tapping noise when I went over bumps or accelerated and decelerated hard and I discovered one of the torx screws on the wheel liners had come away from the inner wing and was flapping about. It made it sound like a tinny tapping noise. Just a thought.
Sent from my SM-N910F using Tapatalk
Offline DomBacon
« Reply #2 on: September 10, 2016, 10:53:57 am »
I'll have a look but I don't think it'll be that. Cheers anyways
Offline DomBacon
Re: Weird knocking noise
« Reply #3 on: September 11, 2016, 03:09:17 am »
Can anyone else help?!
Offline AJP
  • -Given: 392
  • -Receive: 316
« Reply #4 on: September 11, 2016, 11:25:56 am »
Subframe bolts? Quite regularly documented. In fact, there's an aftermarket set of bolts that fix this, made by Tyrolsport.
Offline SurreyED30
« Reply #5 on: September 11, 2016, 11:30:12 am »
I was going to say subframe aswell, my first eddy had similar noises and I also had the complete revo/eurojet mounts. Fitted the subframe spacer kit and also replaced all the other bolts and it stopped
Offline Nickd57
« Reply #6 on: September 12, 2016, 09:24:31 pm »
Cv joint have play in the splines between joint and shaft?
