Author Topic: Cruise Control Retrofit and MFSW install - is this expensive?  (Read 858 times)
Offline jaylufc17
  • -Given: 48
« on: September 15, 2016, 02:55:34 pm »
Own a 57 plate GTI DSG MK5 and got a quote to to retro fit cruise control and install MFSW buttons (I have already purchased the buttons of @
Basically I have googled the loom and can see its around £25-£30 mark however if the part is not needed then I'll just be stuck with the item unless I find someone that's willing to let me return.
Just wondering whether the below is pricey?
I did a bit more digging in to fitting the buttons to a non multifunction wheels and it looks like the loom you need should be 1K0 971 584 C which is £53.04 including VAT from VW. We can supply that if you need us to. While I was looking for that part number I noticed that your current steering wheel will need to be modified to accept the buttons and control module which I hadn't accounted for in the original quote so that would need to be adjusted slightly.
So to confirm we have:
Supply and fit cruise control stalk - £137 inc VAT
Harness for buttons - £53.04 inc VAT
Fitting buttons - £30 inc VAT
Total: £220.04 inc VAT.
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
Re: Cruise Control Retrofit and MFSW install - is this expensive?
« Reply #1 on: September 15, 2016, 03:58:38 pm »
where r u based?
I will have a CC for sale soon, can do it for £60 fitted
Offline jaylufc17
  • -Given: 48
« Reply #2 on: September 15, 2016, 04:07:56 pm »
Solihull... are you near?
