Author Topic: Air con re-gas  (Read 1994 times)
Offline Lewo
Air con re-gas
« on: September 18, 2016, 10:35:46 am »
Seen a deal for a service & re-gas for £20 at a HIQ garage. Price is tempting of course  :smiley:
Are these types of places ok to get this done or too cheap to be a good job, or they find faults that 'need' fixing or is it best to go to VW or an independent?
Not having had this done before I don't have a clue how much it would cost going to one of these places but guess it would be a lot more.
Ta very.
Offline Martk19871
  • Va Va Voom
Re: Air con re-gas
« Reply #1 on: September 18, 2016, 01:30:27 pm »
I tend to get my aircon regassed as the cheapest place, it's not exactly a technical job so Hi-Q should be fine IMO.
Offline shail
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,99663.msg979899.html#msg979899
Re: Air con re-gas
« Reply #2 on: September 19, 2016, 01:37:40 pm »
FYI VW charge £79 for an Aircon service, which includes the re-gas.
I'd just go with the £20 one.
Offline Lewo
Re: Air con re-gas
« Reply #3 on: September 19, 2016, 05:40:53 pm »
Cheers guys, just had another look at the deal and it says ....
'An Network Tyres mechanic breathes new life into air-conditioning units with a service and re-gas. After a thorough inspection, any pesky leaks are identified in a pressure test. The job comes to a close as the mechanic re-lubricates the system with fresh oil and recharges it with refrigerant.'
Just wondered what the re-lube is about?
I'll get it booked in anyhow I think.
Offline Flyingscotsman
Re: Air con re-gas
« Reply #4 on: September 19, 2016, 06:24:25 pm »
You can regas yourself with a DIY kit from halfords for about same cost. I guess the £20 "service" is a loss leader to find any eaks or problems with your system that you'd have to pay to fix. If system OK it's a good deal.
Like a "free tyre check" from kwakfot
Offline shail
Re: Air con re-gas
« Reply #5 on: September 20, 2016, 10:09:22 pm »
The gas they put in contains a lubricant which is needed to keep seals in good shape and help reduce leakage.
