Author Topic: MK5 Radio Upgrade  (Read 1599 times)
Offline tomkingshott
MK5 Radio Upgrade
« on: September 18, 2016, 05:46:09 pm »
hi all,
im completely new to VW's coming from a whole host of Fords previously. I have just bought a 2006 GTI and i'm looking to change a few things on it. But my main one is the radio, I've had DAB in my last 2 cars and i miss it quite alot so i'm looking to change the headunit. I've seen the VW RCD510 that has DAB on it, what else is needed to make it work in the car? I presume it's not just a plug and play system?
4ndy
Re: MK5 Radio Upgrade
« Reply #1 on: September 18, 2016, 06:43:31 pm »
 Pretty sure you'll need a new gateway upgrade then this
http://www.dabonwheels.co.uk/Kinetic_DRA-6003_FM-AM_DAB_car_aerial.html
 This option with the cable has served me well for years
 Easy install   If you get stuck just ask
« Reply #2 on: September 18, 2016, 07:14:27 pm »
so i need a new aerial, headunit and then a gateway upgrade? headunit i can probably fit think the rest is beyond my capabilities with electrics!
« Reply #3 on: September 20, 2016, 02:30:34 pm »
which aerial should I get sorry? managed to source a rcd510 from pashka on this forum so I just need the aerial/antenna and then I should have the full kit
4ndy
« Reply #4 on: October 01, 2016, 07:01:51 pm »
have a look "dabonwheels"  Your gateway will be ok if its suffix K or later  If you need a new one they can be bought precoded ready to install from "Eddie-NL" on here
Offline croak2012
  • My first Gti mk5
« Reply #5 on: October 01, 2016, 11:44:12 pm »
my reception is rubbish radio 1, 2 KISS FM , CAPITAL EXTRA but not much else! might do some research on this :) thanks.
4ndy
« Reply #6 on: October 02, 2016, 07:46:50 am »
http://www.dabonwheels.co.uk/Kinetic_DRA-6003_FM-AM_DAB_car_aerial.html   This one has served me well for 3 years  Use plenty of lithium grease on the underside of the mast base.
