Author Topic: Slight hiccup on idle BKD  (Read 1315 times)
Offline Vwgtiking
« on: September 18, 2016, 08:46:30 pm »
Ok have had this since owning the car. I have tested the injectors and the tolerance should be -2.8 to +2.8. Mine vary between -0.20 to +2.0. So not the injectors.
I have also cleaned the inlet manifold and removed the egr valve.
No fault codes. Any ideas?
Someone said flywheel?? But that was done about 3-4yrs ago (about 30k).
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
Re: Slight hiccup on idle BKD
« Reply #1 on: September 19, 2016, 03:34:20 pm »
How did you test your injectors ?
Silver is the way !
