Author Topic: Interior lighting  (Read 7534 times)
Offline Stig_gti
Interior lighting
« on: September 19, 2016, 04:03:19 pm »
Hi guys I have a mk6 gti.
Problem is with the interior lights not coming on when you open the doors any of the doors. Bulbs work fine because they work when you switch them on, foot well lights also work when I unlock the car and open the doors. It just seems to be the roof lights not coming on.
Offline th3_f15t
  • -Receive: 183
Re: Interior lighting
« Reply #1 on: September 25, 2016, 06:42:44 pm »
Checked things like the fuses, as the door open sensors may be on another circuit to the lights themselves? At least give them all a push to ensure they're seated correctly.
Offline Stig_gti
« Reply #2 on: September 26, 2016, 08:43:39 am »
Thank you I will give them a check over.
Weird thing is they don't come on even when you unlock the car with the key fob iver. Only something minor but annoying as its getting darker earlier now with winter on it's way.
Offline Stig_gti
« Reply #3 on: October 04, 2016, 09:28:05 pm »
Anymore ideas on this.
Offline th3_f15t
  • -Receive: 183
« Reply #4 on: October 05, 2016, 09:40:47 am »
Have you the ability to get a fault scan done? That will likely tell you what's wrong.
Offline Stig_gti
« Reply #5 on: October 05, 2016, 11:37:24 am »
I don't have no scanners or vag com.
I surpose I should get it booked in to a garage probably make life a lot easier.
Thanks will
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #6 on: October 05, 2016, 09:20:25 pm »
Have you checked the actual light holder for a loose switch?.
Offline Stig_gti
« Reply #7 on: October 05, 2016, 09:56:32 pm »
I've had a quick look didn't notice anything. They work if you use the switch it's self, just don't work when unlocking the car and opening the doors any doors. Weird
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #8 on: October 05, 2016, 10:38:09 pm »
Now that Is a weird one  :thinking:
Offline Rowley102
  • My Ride: 2009 VW MK6 Golf GTI
« Reply #9 on: January 25, 2017, 09:35:18 pm »
Hope you got it solved but if not i had the same problem, I had to replace my whole unit think it was about £60 as the conections had corroded on it, take it off and have a look on top of the unit. Its relatively easy to take out have a look on forums there will be a how to guide
2009 Golf GTI 2.0, Tornado Red, Engine code: CCZB, Manual, RCD 510, Bluetooth, Heated leather seats, Cruise control, 225/40/18 Goodyear Eagle F1 Asymmetric 3s, Monza Shadow Alloys, Millers Nano-drive 5W-40
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #10 on: January 26, 2017, 02:21:42 am »
No one ever gets back with a resolved and disappear  :signLOL:
Offline Stig_gti
« Reply #11 on: January 26, 2017, 08:18:28 am »
Sorry thought I did reply with the outcome.
Yes same problem the connection has corroded
And it's not making a good connection.
Where did you get your new unit from vw.
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #12 on: January 26, 2017, 12:15:44 pm »
Sorted  :happy2:
Offline ady-uk
  • -Given: 19
  • -Receive: 24
« Reply #13 on: February 20, 2017, 05:16:12 pm »
be the switch......bet you've a three bulb version, whch drew too much current and slowly burnt the contacts.
Now superseded with centre light omitted and just the two outside lights.
If you still want three then second hand only and hope you get a good one :(
I found a good three bulb version and replaced with led bulbs....hardly any current draw so should be fine :D
http://www.mk5golfgti.co.uk/forum/index.php/topic,106611.msg1033846.html#msg1033846
VW Golf 2.0 Gtd 140 4motion (2005)
Factory fitted: xenons, sunroof, heated leather seats, fold in mirrors with downlights,
Custom: Mk6 steering wheel, updated gateway, RNS510 remote boot pop, LED lighting.
