Author Topic: Fuel pressure deficiency...  (Read 11582 times)
Offline jhook661
  • -Receive: 20
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,98678.0.html
Re: Fuel pressure deficiency...
« Reply #15 on: November 21, 2016, 07:39:48 pm »
If the fuel pressure is good then why are you running lean? Logs? You know the fuel request is adjustable, right?
I'll put some logs up this week and what do you mean by adjustable ? @Dan_FR
Is there any other reason why it would run lean if it's fuelling correctly, I'm confused  :ashamed:
« Last Edit: November 21, 2016, 07:43:19 pm by jhook661 »
Modded Golf gti CDL engine TTE420 turbo
Rtech 440bhp 429ftlb
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
« Reply #16 on: November 22, 2016, 06:22:35 am »
Revo software allows the specified fuel request to be set by the user/dealer. If you are running lean then I would suspect the software has not been set correctly or you have a hardware issue. Will know more with some decent logs
« Reply #17 on: November 22, 2016, 01:02:11 pm »
I'm having similar issues too I'm Revo stage 3 k04 conversion the car on full boost after 4K is dangerously lean so the ecu is pulling it back and mine has all new parts
Fuel filter 6.6 bar
Loba hpfp
Rs4 return valve
Brand new s3 injectors
No boost leaks or vacuum leaks either
Fuel pressure is good too
And top of all this the idle is shocking to it hunts and choughs but revs never drop or fluctuates  :thinking:
Your last sentence is typical of a blown front PCV.  Might be worth checking / replacing it.
Offline jhook661
  • -Receive: 20
« Reply #18 on: November 22, 2016, 06:55:24 pm »
Pcv valve has been checked, I'll do some logging on rail pressure and boost etc give you guys some idea but I'm not as knowledgable as you guys on the vcds
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
  • K04 PLAY....ZOOM DIS!
« Reply #19 on: May 18, 2022, 05:11:49 pm »
Is the lpfp controller OEM or aftermarket?
Certainly looks like the problem is in the lpfp area, which I did steer you in the direction of in my first reply  :smiley:
Been a long while...only now saw this and realized I never finished it.
After going through this all, and going back and forth with GIAC, I finally figured out the GIAC Dealer had loaded the incorrect file. And this was after having replaced the OEM LPFP__LPFP control module__S3/Golf R - injectors__both pressure sensors__HPFP and internals...etc. etc. etc..
I appreciated all of the time, thought and energy you all spent on this with me.
« Reply #20 on: May 19, 2022, 09:14:42 am »
Blimey, where does the time go!
Glad you got it sorted in the end  :happy2:
Apparently there are 4 separate maps just for the LPFP, so it's understandable mistakes can be made in that area.
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
« Reply #21 on: May 19, 2022, 05:13:19 pm »
Thanks...I see where you asked about the LPFP control module. I actually had the Torqbyte PM3, and it was paired with the TTRS pump, but the problem persisted when I deleted all that and went back to just the OEM module and OEM pump. Two years ago, following the rebuild, is when I swapped the injectors and returned to the OE control module and pump, new HPFP and upgrade, and tried an aftermarket LPFP upgrade (which failed to operate) in the original basket. Nothing helped. So I had reached the point of nothing left to try. I was literally stumped...and it then took some digging through GIACs records for them to find and then retrieve the exact file name that their dealer selected to be loaded back in 2016. And then more time finding the one loaded way back in 2010 or 2011. This original file we sought was a to be the file I had prior to trying the DM tune in 2014. When we found and got that one loaded, all was good again.
« Last Edit: May 19, 2022, 08:55:35 pm by ROH ECHT »
« Reply #22 on: May 20, 2022, 08:45:30 am »
Blimey, what a journey that was.  We don't generally mess with the LPFP side in Europe unless running hybrid/big turbo conversions, hence why I was curious about why you needed a bigger pump and controller for a K04 conversion. The stock LPFP setup easily supports 370 crank power on K04 cars over here  :smiley:  The tunes here don't tend to go richer than 12:1 though, maybe 11.5-11 AFR approaching the redline.
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
« Reply #23 on: May 20, 2022, 05:10:36 pm »
I looked at some old logs just now. Fuel ratio for then, throughout a full rev run, was generally 12.1 to 11.6 nearer to redline.
The addition of the upgraded pump and controller was per the tuner. The DM tune was an 'E-tune' if you will. He sent the loader and emailed a base file for me to load onto the ECU. I would do so and log data to send back via email. He would make any adjustments if he felt it necessary and return to me a revision if and when done, until it was finalized (about six months). He had it boosting to near 28 psi peak and holding a 25 psi minimum. My delivery fueling was found during the process to be suffering, and thus the upgrades were added. The rail pressure was set at 142.5 bar.
