Hi All,
Would just like to know how often should you be changing the following?
Spark Plugs
Pollen Filter
Air Filter (stock car)
Fuel Filter
Brake Fluid
Cam follower should be checked every major service?
Anything else in basic servicing?
3 ways you can go about it, Follow the VW Service Intervals which is every 10000 Miles, Longlife Scheme which I think personally is far too long or do it more often. My cars are the latter! I do about 6000 Miles per Year.
I always fit Genuine Parts with the exception of the Spark Plugs and Engine Oil (Millers Nanondrive)
Firstly Engine Oil & Oil Filter =
Every Year or 6000 Miles whichever comes first.Spark Plugs =
VW say every 60K Miles, I fit NGK BKR7EIX's and would replace them every 2 Years/2nd Oil Change which would be between 12000-15000 Miles with my Mileage.Pollen Filter =
Every 2 Years/2nd Oil ChangeAir Filter =
Every 2 Years/2nd Oil ChangeFuel Filter =
Every 2 Years/2nd Oil ChangeBrake Fluid =
Every 2 YearsAnti Freeze =
Every 4 Years when the Timing Belt and Water Pump are replacedCam Follower =
I would say inspect it every 2 Years which for me is not very much Mileage at all, However if you are taking the HPFP off to inspect it and take out the follower you might as well just fit a new one in my opinion. If you take it out and find some wear it would do my head in to refit the part only to have to take it all apart again.All of the above has been done on my car in the last 300 Miles, The Brake Fluid was changed earlier this Year when the car had a Genuine rear Brake Caliper at the Dealers and the Anti Freeze will be done in 2 Weeks when the car has its Second Timing Belt as its now 8 Years old.
