Author Topic: what is your bulb setup for xenon headlights?  (Read 6506 times)
Offline croak2012
  • My first Gti mk5
« on: October 06, 2016, 11:30:00 pm »
I'm going to upgrade my halogens to xenons so just wondering what bulb setup / vcds setup you guys have and recommend  ?
thanks
Ian
« Last Edit: October 06, 2016, 11:31:32 pm by croak2012 »
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
  • K04 PLAY....ZOOM DIS!
Re: what is your bulb setup for xenon headlights?
« Reply #1 on: October 06, 2016, 11:42:02 pm »
http://www.newvwparts.com/auto-parts/2007/volkswagen/gti/base-trim/2-0l-l4-gas-engine/electrical-cat/headlamp-components-scat/?part_number=1k6941039b
If this doesn't help you figure the bulb situation...I can try.
As far as the vcds setup...wuhchumean?? I run my fogs as DRL's and have the inner halogens set to flash-to-pass...and fogs to stay on with high beams.
Offline croak2012
  • My first Gti mk5
« Reply #2 on: October 06, 2016, 11:53:42 pm »
Hi roh excvt - from american forum haha ,....As far as the vcds setup...wuhchumean?? I run my fogs as DRL's and have the inner halogens set to flash-to-pass...and fogs to stay on with high beams.
thats exactly what I mean haha - some yt vids I have watched they mention changinbg drl setup etc... Also I mean what brand of bulb ... ie what light color and brand. e.g . osram intense blue  , nightbreakers ,etc.     are fogs not illegal as drl in uk
« Last Edit: October 06, 2016, 11:57:23 pm by croak2012 »
Offline croak2012
  • My first Gti mk5
« Reply #3 on: October 07, 2016, 12:01:32 am »
... also I know you're from the usa mkv forum haha so the law concerning drl might be different in uk but not sure.... I would love to know if anybody knows?...
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #4 on: October 07, 2016, 05:46:04 am »
When I had genuine xenons I had osram night breakers in full beam, quantum d2s bulbs in dipped and led in side light.  Ive done the flash to pass mod so when lights are off and u flash, only halogen flashes, and when lights are on and you flash, only the shutter opens
Now I've got depo ones, got a yellow bulb in full beam, 5000k bulb in dipped and led side light
Sent from my SM-G928F using Tapatalk
Offline slix
  • -Receive: 38
  • Stage 1 ED30 Owner
« Reply #5 on: October 07, 2016, 09:49:48 am »
This flash to pass mod.....
I have aftermarket projectors fitted and when I flash full beam (with headlight off) the old halogen bulbs flash, but if headlights are on at night the shutter opens in the projector and they flash as well as the hold halogen full beam bulbs. I take it the mod you're mentioning changes this so at night when headlights are on the car only uses the xenon projectors to flash and bypasses the halogen?
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #6 on: October 07, 2016, 09:56:50 am »
Correct, I had to do a tweak in VCDS . But it only works on OEM xenons. This is how its set up in the USA Golfs
Offline DANBOY66
  • -Given: 41
« Reply #7 on: October 07, 2016, 10:01:04 am »
flash to pass is great had it enabled on my ed30 but the cluster beeping at me every time i opened the door  :fighting:
my current golf i have not even wired up the bi xenons  :grin:
Dan..
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #8 on: October 07, 2016, 10:08:08 am »
Yeah it gets annoying, but I think only if the keys are left in the ignition
Offline slix
  • -Receive: 38
« Reply #9 on: October 07, 2016, 10:17:46 am »
Oh so I won't be able to on my aftermarket xenons?
Ah well. Maybe it's not a bad thing having double the full beams going off at once  :grin: lights up the road real good in pitch black Country lanes.
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #10 on: October 07, 2016, 10:19:23 am »
Yeah because your shutters arent controlled by the shutter wires from the CECM, it wont work
Offline croak2012
  • My first Gti mk5
« Reply #11 on: October 07, 2016, 10:27:50 am »
thanks, sounds like a good set up I take it your yellow bulb is something like Nokya Stage 1 Hyper Yellow H7 and any can bus error free led from ebay?
is it a bit of hassle to wire it up?
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #12 on: October 07, 2016, 10:41:58 am »
@croak2012
Yes its those Nokya ones. looks good as it matches the yellow laminx tint i done on the fogs.
Wiring it is easy if youve done it before lol. Just get it routed through the bulkhead, take off the under glove box foam and a few plastic panels, run it to the cecm, unclip plugs A and D, and i think its pin 5 on plug A and pin 6 on plug D.
Working on the cecm is the trickiest as its really tight space
Offline croak2012
  • My first Gti mk5
« Reply #13 on: October 07, 2016, 10:50:51 am »
@croak2012
good to know - I have bookmarked  retrofit xenon "how to guide" that is floating about- so will probably go ahead and wire it in at same time as installing xenons... if you have yellow fogs light bulbs  surely you don't need laminx too?
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #14 on: October 07, 2016, 10:59:05 am »
@croak2012
nah my fogs were normal halogen bulbs, couldnt find/afford yellow bulbs at that time.
