Author Topic: Headlamp upgrade ??  (Read 4978 times)
Offline Ray
Headlamp upgrade ??
« on: October 09, 2016, 03:06:47 pm »
Hello I'm still new to this as I've only posted 1 thread. Which was about my broken golf. I have now finally got a working one, nothing like what you guys got. 1.6fsi so won't be wasting money on performance as I won't be able to get much
Anyway cut to the chase
I want to put the bi xenon headlamps on my car which has the standard headlamps. Is it a direct replacement or "things have to be done. If I do get bi xenon headlamps I'm going to put after market hid anyway so yeah I'd just like to know if it's a direct replacement
Offline Ray
Re: Headlamp upgrade ??
« Reply #1 on: October 17, 2016, 10:15:58 pm »
I don't get it. No one wants to help. Or is it cus I'm trying to rice out a 1.6 :thinking: :thinking:
Offline 99hagued
« Reply #2 on: October 18, 2016, 12:48:25 am »
http://www.mk5golfgti.co.uk/forum/index.php/topic,109414.msg1058781.html#msg1058781
These are what you need mate they are genuine Bi xenon headlights.
If you go aftermarket look for depo or hella projector style headlights and buy a hid kit for them.
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #3 on: October 18, 2016, 08:13:09 pm »
You'll need to check if your CECM will support xenons before you go splashing out for these....
I'm sure Ray that's why you might not have received much help, 1.6 is a bit of an unknown i'd say and not sure what it comes with from factory.... If you have VCDS or access to it, throw up a scan and we can start to work out what you might be able to add  :happy2:
Offline Ray
« Reply #4 on: November 01, 2016, 09:45:25 pm »
Thanks guys for the reply. The link is blocked for me. Maybe cus I'm still new. I thought that all golf's were the same except the engine and the extra options.
Anyway I found these headlights with the 9 pin connecterror instead of the 12 pin. They say direct replacement for the halogen headlamps.
http://eurowagens.com/headlights-set-projector-chrome-vw-golf-mk5-jetta-mk3/
What still want to know is can I use the same hid I have in my halogen headlamps or do they have different connections. I called them up and they was no help.
If you guys have bixenon would be great if you could send me a picture of the bulb connections
Offline mk5Eire
« Reply #5 on: November 01, 2016, 10:14:21 pm »
Hid's in reflector headlights really aren't a good idea mate they are quite blinding.  Go for projectors instead
Sent from my SM-G930F using Tapatalk
Offline 99hagued
« Reply #6 on: November 02, 2016, 12:17:40 am »
If the bulbs from your hid kit are h7's then they should fit mate
Offline Ray
« Reply #7 on: November 24, 2016, 10:31:40 am »
Yeah that's why I took out the hid because they are blinding in the reflectors. So I was hoping I could fit the gti style headlamps with the projector.
So normal gti headlamps take h7 bulbs. Because mine are h7 xenon
