Author Topic: Golf Mk5 Diesel  (Read 1470 times)
tango Charlie 89
Golf Mk5 Diesel
« on: October 09, 2016, 05:44:27 pm »
Hi Guys new to this forum, been recommended by a friend as I have problems with my Mk 5 Disel Golf, its terrible to start when hot and when I go though a puddle is judders really bad, any ideas
Andy
Offline xjay1337
  • -Receive: 377
Re: Golf Mk5 Diesel
« Reply #1 on: October 09, 2016, 06:30:23 pm »
Hot start is common fault. Ecu tune resolves it.
Going through a Puddle and causing issues is probably something else entirely.
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
Re: Golf Mk5 Diesel
« Reply #2 on: October 09, 2016, 07:28:23 pm »
Remap the hot start issue out, judders when in puddle probably bad tyres?
Sent from my SM-G928F using Tapatalk
Offline Pashka
Re: Golf Mk5 Diesel
« Reply #3 on: October 09, 2016, 08:32:25 pm »
Andy
Change the starter motor for hot start. Ecu tune fix injects the fuel from 0/200 rpm, but not solve the issue.
« Last Edit: October 09, 2016, 08:36:05 pm by Pashka »
06 1.9 TDI Owner. Retrofits: Bixenons, Drls, Full GT/GTI exterior, RNS510+MDI+Premium Bluetooth+RVC+OPS, Full Fis, MFSW, Cruise control, TPMS, Polar Fis, Boot pop up and more.. :)
Coding, diagnostic and retrofits in Leeds
Pre coded Can Gateways for battery drain issues with RNS510 and similar headunits
Premium Bluetooth modules/kit
RNS510 Service - codes, maps/firmware updates
Latest V8 West EU maps update service for RNS315
Re: Golf Mk5 Diesel
« Reply #4 on: October 09, 2016, 08:48:20 pm »
mine had this
changed the starter motor and it sorted it
Offline jason_rmh
  • -Given: 69
  • -Receive: 81
Re: Golf Mk5 Diesel
« Reply #5 on: October 10, 2016, 09:22:12 am »
+1 for starter motor.
Some people change the battery which masks the issue, but eventually it's down to the starter motor.
VCDS (Preston, Lancashire)
Offline xjay1337
  • -Receive: 377
Re: Golf Mk5 Diesel
« Reply #6 on: October 10, 2016, 12:31:13 pm »
People have replaced starter motor and issue has happened again after a few months.
ECU tune is £50 or £60. New starter motor can be 3 or 4 times that amount.
While I agree the "proper" fix is a new starter motor, clean any corrosion on points around the area, check wiring, fit new battery and the ecu tune combined, doing the ecu on it's own is the cheapest.
