Author Topic: Help needed, turbo issue...!!!  (Read 1672 times)
Offline Danjamhow
« on: October 10, 2016, 08:38:09 pm »
Driving home from work today I went to give the gti a little hoon, traction control started kicking in so I let off the throttle and switched to second, after that the car started making a whooshing sound when accelerating and had lost power and kept either stalling or trying to stall, limped it home and checked it out and a pipe under the cambelt has come loose, I assume it's to do with the turbo as the car is now making a suction whooshing sound, different to the normal turbo sound, is this likely just to be a popped pipe that just needs reclipping or has something catastrophic happened
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
  • K04 PLAY....ZOOM DIS!
Re: Help needed, turbo issue...!!!
« Reply #1 on: October 11, 2016, 03:02:53 am »
Yep...likely it just popped off. Perhaps wasn't clamped properly when some other work was performed. Should just need reattaching...but if it is the boost pipe(pictured below @ link) and has a large o-ring on the coupler, you may want to replace that o-ring before snapping it back together to insure it will hold all boost for years to come.
Does what you speak of look like this: http://c1552172.r72.cf0.rackcdn.com/106888_x600.jpg
« Last Edit: October 11, 2016, 03:08:05 am by ROH ECHT »
Offline Danjamhow
« Reply #2 on: October 11, 2016, 06:59:04 am »
Yeah that does look similar and would make sense, I looked on google and apparently it could be the turbo discharge pipe which looks a bit different to that, or is it the same thing, i regret to say I'm a real noob with all this stuff so you'll have to bear with me  :signLOL:
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
« Reply #3 on: October 13, 2016, 07:07:28 pm »
This section looks to be from the cast bit of the discharge pipe to the intercooler.
Offline Danjamhow
« Reply #4 on: October 14, 2016, 08:27:37 am »
You were spot on pal, just put it back on and its running fine. Thanks for your help
Offline ducman77
  • -Given: 59
« Reply #5 on: October 14, 2016, 12:11:20 pm »
Awesome work ROH - and pleased you got sorted Danjamhow - well done men :happy2:
