Author Topic: flashing lights after xenon install  (Read 5077 times)
Offline croak2012
  • My first Gti mk5
« on: October 12, 2016, 06:09:26 pm »
if i run wire into cecm will this stop flashing or o i have to vag com to sort this? thanks
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
Re: flashing lights after xenon install
« Reply #1 on: October 12, 2016, 06:10:51 pm »
What do you mean by they are flashing?
Sent from my SM-G928F using Tapatalk
Offline croak2012
  • My first Gti mk5
« Reply #2 on: October 12, 2016, 06:13:39 pm »
i just installed them, and then switched beam on and they flickering - now they are not on at all @RetroRaz
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #3 on: October 12, 2016, 06:16:30 pm »
I'm guessing you haven't coded them? They will flicker until you can code them and tell the car Xenons are fitted
Offline croak2012
  • My first Gti mk5
« Reply #4 on: October 12, 2016, 06:17:59 pm »
they come on  when I open door (leave home feature) then they flicker if i put lights on or leave in on auto. @fab5freddy
Offline croak2012
  • My first Gti mk5
« Reply #5 on: October 12, 2016, 06:18:58 pm »
even if i wire in the yellow wires to cecm  quickly (bi xenon shutter)
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #6 on: October 12, 2016, 06:23:35 pm »
They need coding buddy, your car has been coded to run with halogens, it now needs to know it's running xenons, a simple check box in VCDS will sort the flickering.
Running the wire back to the CECM is totally different function and has no bearing on the flickering your experiencing.
Check the VCDS register for someone close by who might be able to help you out  :happy2:
http://www.mk5golfgti.co.uk/forum/index.php/topic,88875.0.html
Offline croak2012
  • My first Gti mk5
Re: flashing/ flickering lights after oem xenon install
« Reply #7 on: October 12, 2016, 06:36:01 pm »
thanks for clearing that up - I'm gong to danboy66 to code later tonight!  seem to be able to turn them on by pulling out light switch for fogs lol.
« Last Edit: October 12, 2016, 06:47:15 pm by croak2012 »
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #8 on: October 12, 2016, 07:57:04 pm »
as mentioned, either coding OR you may have got non canbus friendly lights in there
Offline croak2012
  • My first Gti mk5
« Reply #9 on: October 12, 2016, 09:18:36 pm »
 I pulled out fog lights switch and then the dimmed lights started to work again??? enabled me to drive to dan in the dark!   - and then when I flashed high beam the disco started again?
dannyboy66 sorted coding for me so thanks for all the info!
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=btluvm6ekkddiq8lj2rcmgcf9m&/topic,19740.0.html
« Reply #10 on: October 12, 2016, 09:43:55 pm »
Needs coding... I had this issue on my old mk5 tdi when I installed xenons.
To start I though i had got away with coding until i flashed my lights then DISCO TIME!  :signLOL:
Offline croak2012
  • My first Gti mk5
« Reply #11 on: October 12, 2016, 09:54:03 pm »
dico disco... reminds me of the movie with adam sandler " you don't mess with the zohan"  hahah  :jumpmove:
Offline Kcmillar
  • Newbie
« Reply #12 on: February 21, 2020, 03:58:09 pm »
I know this is an old post BUT I have just fitted xenons on my mk5 golf that came from a gti edition  30 and have the flashing lights. Can someone point me in the right direction for coding as I have tried with several vcrs and nothing seems to stop this happening I think I'm missing something. Thanks
