Author Topic: Looking at a Mark 6 GTI and need advice  (Read 1997 times)
Offline Misschief
« on: October 14, 2016, 04:40:13 pm »
I've been looking for a GTI or an Ed. 30/Pirelli for a couple of weeks now and being in Scotland means most are inevitably down south.
However, this Mk. 6 GTI, http://www.autotrader.co.uk/classified/advert/201608267159506 has come up for sale not too far away. Having been looking at Mk. 5's all the time I'm not sure what, if anything I should be looking for. There's plenty of service history but nothing indicating the timing belt has been done so I'd be looking for £500 off or it to be done prior to me taking it.
So, is there anything unique or particular to the 6 I need to be careful of? I pulled the dipstick while the engine was running and it started to falter so DV valve should be OK? If that's the right thing! Is there anything else I should be looking at or worried about? It's very clean inside, hardly any wear at all really and certainly wears it's 78k miles very well indeed. Thanks in advance.
Offline Kai96
Re: Looking at a Mark 6 GTI and need advice
« Reply #1 on: October 14, 2016, 06:16:58 pm »
I recall the earlier one's like that model had a fault with the engine ? Something like the chains snapping but I'm not to sure. Someone more knowledgeable will be along in a minute and give you more info
Offline Misschief
« Reply #2 on: October 15, 2016, 01:09:10 am »
I've been reading a little about the Cam chain adjuster failing on this particular engine, across all VAG brands and it really feels like it's luck of the draw.
