Author Topic: ECU Fault  (Read 885 times)
Offline TheBALDpuma
ECU Fault
« on: October 15, 2016, 01:44:55 pm »
This links on from my previous thread about all the warning lights (EML, ECP, ESP and tyre pressure) but has taken a little turn so thought I'd post with a more sepcific thread title.
The original fault was due to a faulty throttle body.  When they put a new one in the couldn't get it to pair with the ECU - something to do with it not taking the base settings.  They have tried the throttle body in another car and it worked fine, so that's been ruled out being faulty out the box.  They have changed all the wiring and connections betweem the ECU and TB but no luck.
Ultimately they have exhausted all option except the ECU, so that is being sent off next week for repair.  Has anyone had similar?  Do you think a repair will work?
I can see three scenarios here...
1.  There is no ECU fault...  What else could be wrong!?
2.  There is an ECU fault, it gets fixed and we're all good, but £Wedge lighter.
3.  There is an ECU fault, and they can't fix it... I'm assuming a replacement is going to be silly money?
Just FYI I fully trust the garage that are doing the work, I'm just at a point where I can't do anything and I'm musing over what could happen!
Offline AJP
  • -Given: 392
  • -Receive: 316
Re: ECU Fault
« Reply #1 on: October 15, 2016, 02:47:56 pm »
Regarding option 3, could you not pick up a used ECU for a bit less money?
Offline TheBALDpuma
Re: ECU Fault
« Reply #2 on: October 15, 2016, 02:54:33 pm »
I'm pretty ignorant about all of this...
How much is a new one?
How much is a 2nd hand one?
How easy would it be getting a 2nd hand one? Would pirelli and ED30 be interchangable?
Can you just swap ECU's between cars?
