Author Topic: How just how  (Read 6822 times)
Offline WaLLeMs
How just how
« on: October 15, 2016, 02:56:52 pm »
How is Gods name do you get the carrier off with so much space just how... I have given up
Sent from my A0001 using Tapatalk
Offline stuart-88
  • -Receive: 21
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,101197.0.html
Re: How just how
« Reply #1 on: October 15, 2016, 03:08:13 pm »
Bigger bar or get a ratchet on and stand on it. Plus lots of swearing.
Instagram: stu_nc88
4ndy
Re: How just how
« Reply #2 on: October 15, 2016, 03:10:23 pm »
600mm breaker bar and a rubber mallet
Offline WaLLeMs
Re: How just how
« Reply #3 on: October 15, 2016, 04:12:18 pm »
But how... There is zero space mate... The fronts were easy as you could just turn the wheel outward
Offline 99hagued
Re: How just how
« Reply #4 on: October 15, 2016, 04:27:19 pm »
This is where a ramp comes in handy mate or a air gun
Offline WaLLeMs
Re: How just how
« Reply #5 on: October 15, 2016, 04:43:14 pm »
Was just looking at going to buy one before I start destroying things hahaha
Re: How just how
« Reply #6 on: October 15, 2016, 04:52:53 pm »
if you have a piece of pipe,plot it over your ratchet to give more leverage
Offline 993BOY
  • -Given: 18
Re: How just how
« Reply #7 on: October 15, 2016, 05:14:36 pm »
Just changed mine, it is a pig, but if the car is jacked up higher, you can get a better angle on it and have the breaker bar at 6 o'clock position.
I couldn't torque mine up as not enough clearance to get the torque wrench into position, so just tightened it as much as I could with my  ratchet!
Offline Flyingscotsman
  • -Given: 26
Re: How just how
« Reply #8 on: October 15, 2016, 05:43:05 pm »
It is tight but you can get a short breaker bar in. I used a universal joint on the socket and managed to get breaker bar and torque wrench inside the wheel arch.
« Last Edit: October 15, 2016, 09:43:00 pm by Flyingscotsman »
Offline grey golfster
  • -Given: 79
Re: How just how
« Reply #9 on: October 15, 2016, 09:21:48 pm »
Nooooooooooohhhhhh!!!
PLEASE, no extension bars on ratchets! I really get sick of lads at work wrecking ratchets when using scaffold tubes to extend handles. I've seen even quality 3/4" drive ratchets break like this.
Ratchets are for ratcheting!
Use a solid connection, like a T bar or better still a proper breaker bar.
And a proper lump hammer for a solid thwack, not a rubber mallet...
Offline TAPPY
  • -Receive: 56
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,103290.0.html
Re: How just how
« Reply #10 on: October 15, 2016, 10:54:00 pm »
It can be a right pita without the right tools i.e. Ramp, breaker bar, etc
I understand what you mean but snap-on is lifetime guarantee so if it breaks you get it replaced for free  :happy2:
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=ep37fgncdvcjc6kjmdnpbpee0m&/topic,19740.0.html
Re: How just how
« Reply #11 on: October 16, 2016, 11:30:50 am »
I used the proper VW carrier tool and a ratchet. I then hit the ratchet with a hammer to crack it off. Worked fine
  • -Given: 26
Re: How just how
« Reply #12 on: October 16, 2016, 11:53:52 am »
@Rich83 What does the VW tool look like? Is it just like a standard triple square spline socket?
Re: How just how
« Reply #13 on: October 16, 2016, 01:40:43 pm »
Its a short one so gives you more space
Re: How just how
« Reply #14 on: October 16, 2016, 02:38:57 pm »
works fine all the ones i have changed with no trouble
