Author Topic: Ipod adapter help  (Read 4408 times)
Nasir
Ipod adapter help
« on: January 23, 2010, 05:01:02 pm »
Well I almost had it and now I think I know why the adapter didn't power up. Where does the brown wire go? I'll try and attach a picture
Where does that brown wire go? One of them was without a clip and I clipped the end onto the clip I got with it, assuming they clipped into each other.
« Last Edit: January 23, 2010, 05:17:02 pm by Nasir »
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
Re: Ipod adapter help
« Reply #1 on: January 23, 2010, 05:17:36 pm »
Looks like someone has made up a "no cut" type loom to feed off of the main quadlock connector.
As from what I remember of installing one of these the loose wire just needs to be be connected to a suitable ground/earth connection.
Nasir
« Reply #2 on: January 23, 2010, 05:27:44 pm »
The quadlock connector comes out from the blue case. Do I pull one of the wires from the quadlock connector out? The manual doesn't make anything clear.
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #3 on: January 23, 2010, 05:39:04 pm »
I can't be 100% sure it appears the loom has been modified.
Do you have a multimeter to check if the two connectors are joined?
Nasir
« Reply #4 on: January 23, 2010, 05:46:40 pm »
No I don't have a multimeter. The unit was advertised as new and came sealed uswel. The manual shows something similar but I just can't work it out. http://www.mediafire.com/?bommpgdygjf
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #5 on: January 23, 2010, 05:54:03 pm »
You need to take the plastic case off of the connector shown at top of your second picture down.
Then remove the pin as shown on the instructions from the quadlock and put this into the plastic case you removed.
The loose pin from the ipod loom now goes into the quadlock connector and then the two plastic connectors go together  :happy2:
Nasir
« Reply #6 on: January 23, 2010, 06:22:41 pm »
Ahh right, I get it now. How does the brown wire come out of the plastic clip? It seems reluctant :sad1:
Nasir
« Reply #7 on: January 23, 2010, 09:00:46 pm »
Cut the clip in half and glued it back together :laugh:
I'm not sure if the wire comes out of the radio or quad connector. Because the picture doesn't show the connector, it looks like the back of the radio.
Nasir
« Reply #8 on: January 24, 2010, 05:26:47 pm »
Big thanks to Darren for sorting it out for me, best £60 I spent  :signLOL:
Offline mortygttdi
  • -Receive: 146
« Reply #9 on: February 04, 2010, 07:20:30 pm »
No probs mate glad I could help.
Darren
Offline Karlos_Saines
« Reply #10 on: February 10, 2010, 05:44:51 pm »
What was the answer to this???
Nasir
« Reply #11 on: February 10, 2010, 07:21:14 pm »
The wire from the quadlock has to come out, and go into the free clip, this clip then goes into the other clip. The brown wire goes into the space that the other wire just came out of, hope that makes sense. Might need coding uswel.
« Reply #12 on: February 11, 2010, 05:33:30 pm »
Haven't installed yet but I think I understand. Thanks alot  :happy2:
