Author Topic: RCD310 aux cable help please  (Read 1678 times)
Offline david85williams
« on: October 31, 2016, 06:14:46 pm »
Hi all. I want to run an aux cable to my RCD310 unit. Please can someone advise if this is possible?
Thank you and sorry for the noob question!  :smiley:
Re: RCD310 aux cable help please
« Reply #1 on: November 01, 2016, 11:17:31 am »
All sorted. I found the item I need:
http://www.ebay.co.uk/itm/172302058117
LewisMT
« Reply #2 on: November 13, 2016, 03:01:05 pm »
Hi, I've looked at this option to install into my GTI but not sure how to install it and if it will actually work. Does it work and was it easy enough to install?
« Reply #3 on: November 15, 2016, 02:11:33 pm »
Hello,
I actually ended up buying an Android head unit instead but this Aux lead seems easy enough to fit. The radio comes out quite easily. I guess the harder part is routing the aux lead to the blanking buttons by the gear stick. Just more trim to remove I guess.
Good luck if you choose this route. I hear many others having success with this.
