Author Topic: Kufatec loom problems  (Read 805 times)
Offline Max roper
« on: November 01, 2016, 06:27:09 pm »
Good evening everybody! Just got my kufatec loom for heated seats through. I've got the 2007 loom and seats, but got a bit confused when I received the loom and both of the seat connectors have a bridge from  pin 9-8 on both passenger and drivers side. I'm a bit miffed as I've looked at my seats and they don't have pin 9 (where the wire bridges from), so wondering whether I should leave the bridge or just remove it and just use pin 8.
Any info would be golden
-Max
Offline jason_rmh
  • -Given: 69
  • -Receive: 81
Re: Kufatec loom problems
« Reply #1 on: November 02, 2016, 12:50:21 pm »
Have you seen the guide? There are some pictures of the connectors in there that may help.
I will check mine when home, but I guess if you don't have pin 9, it doesn't matter, just leave them?
Jas
VCDS (Preston, Lancashire)
Offline jason_rmh
  • -Given: 69
  • -Receive: 81
« Reply #2 on: November 04, 2016, 12:14:39 pm »
I have check my seats, were also done with kufatec loom.
On the seat side, in both seats, pin 9 is blank.
On the kufatec loom 8 & 9 are bridged.
I just left it as it is, no problems.
Jas
