Author Topic: Your de-icer of choice  (Read 8998 times)
Offline richtung
  • -Receive: 56
« on: November 02, 2016, 07:55:38 am »
Found myself scraping the ice off the car windows this morning - couldn't find the de-icer - mega fail. Need to stock up on de-icer this weekend.
Just wanted what other members' de-icer of choice and why?
I know some people will suggest water but with a newborn and a wife who is unsteady on her feet at the best of times, cant risk her slipping on the frozen water on the driveway.
Suggestions / recommendations please!
Rich
Offline AJP
  • -Given: 392
  • -Receive: 317
Re: Your de-icer of choice
« Reply #1 on: November 02, 2016, 02:55:20 pm »
Anything in a spray can rather than trigger. My fingers tend to seize up squeezing a trigger when it's really cold!
Don't be tempted to use warm water, it can crack the screen due to the sudden change in temperature.
I used some stuff a few years ago that you spray on the night before and it prevents any water freezing. It did work but I was left with this horrible gelatinous mess on the screen after a frost.
Offline Juliand
« Reply #2 on: November 02, 2016, 03:23:01 pm »
A good robust scraper for me. Car always in the garage though, ha ha. Only joking....Scraper always works best for me - hard side to get the worst off, then the rubber squeegie bit to finish. Doesn't freeze over again then.
Has it really been that cold yet?
Offline bonelorry
  • -Given: 72
  • -Receive: 44
« Reply #3 on: November 02, 2016, 04:45:28 pm »
I wont use De-Icer on my car, It will strip off any wax if it comes in contact with the paintwork.
Due to the high acidity of chemicals used in De-Icer the only real way to get around it is to thoroughly rinse off any remaining product left on the paintwork but this is easier said than done.
I avoid using Plastic Ice Scrapers too as these can easily cause scratches on the Glass or Plastic Headlamps, Although a Rubber Squeegee type is ideal for removing any partially De-Frosted Ice or Frost rather than using the Wipers on the car.
I usually use cold Water and keep a 2L bottle of Water in the car at all time, Pour it on the screen with the car running and wait a few moments. Does the job and is harmless.
Interesting thread on DW about defrosting Do's and Dont's...
I would like to say common sense dictates to avoid using boiling water; however, some people are daft enough to pour this straight onto a frozen window. So I would like to take the opportunity to advise you not to use boiling water to defrost a car window
Cold water straight from the tap is sufficient for de-icing your car windows. So much so, that this is all I have used for years. You may be wondering why cold water and not luke warm water? Well the answer is simple, hot water freezes quicker than cold water due to the Mpmeba effect. What you also need to think is that any water is warmer than ice, so it’ll be enough to melt the frozen ice (water) on your car.
After rinsing your windows and lights with water, use the squeegee on your ice scraper to remove any standing water (or your wipers for the windscreen). This will prevent any possible re-freezing of any water left on the windows.
« Last Edit: November 02, 2016, 04:48:31 pm by bonelorry »
Offline shail
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,99663.msg979899.html#msg979899
« Reply #4 on: November 02, 2016, 10:07:03 pm »
I haven't used deicer in a few years - I just switch the car on, heaters on full + recirc and just use an old credit card.
Offline TAPPY
  • -Receive: 56
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,103290.0.html
« Reply #5 on: November 02, 2016, 10:19:21 pm »
I do the same but with a scraper not a credit card haha. I hate de-icer it if only ever found it makes the windscreen smeary and hazy.
My missus has a good technique... put the blower on until a small amount of ice is melted then put the wipers on full and then wonders why she can't see properly once it rains as she's mullered them  :stupid:
Offline baka
  • My Ride: Audi A3 2.0TFSI Quattro
« Reply #6 on: November 02, 2016, 11:15:08 pm »
I just run the hot tap into a crappy old 2 litre jug I've had for years.
Which I chuck over all the glass and mirrors.
Offline dan930
  • -Receive: 56
« Reply #7 on: November 03, 2016, 12:47:56 am »
I just turn up the heaters to max & wait
MK6 golfR dsg
AKS TUNED
NORTECH PERFORMANCE HTA3071
R TECH custom map
Offline Octoparrot
  • -Receive: 104
« Reply #8 on: November 03, 2016, 06:53:42 pm »
Same here  :smiley: and then drive off while all the neighbours are busy scraping away. :happy2:
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #9 on: November 09, 2016, 04:52:12 pm »
GSF have a trigger one which is very penetrative but in yellow liquid  :signLOL: I've used it and it works well.
4ndy
« Reply #10 on: November 09, 2016, 05:02:09 pm »
warm water.. If its really bad I put a heater in the boot for 1/2hr
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #11 on: November 09, 2016, 10:10:01 pm »
do you live in the shetlands ??
« Last Edit: November 28, 2016, 10:37:48 pm by r5gtt »
Offline B19Homer
  • My Ride: Edition 30
« Reply #12 on: November 28, 2016, 03:49:25 pm »
good old scraper does the job
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #13 on: November 28, 2016, 10:38:39 pm »
Too much of a hassle to scrape it these days as people aren't getting any younger  :indifferent:
Offline gulfstream11
« Reply #14 on: December 01, 2016, 12:32:12 pm »
Turn on and wait. Stand outside,the scrotes are watching.
