Author Topic: Which control module for mfsw  (Read 13898 times)
Offline axsweb
« on: November 02, 2016, 01:04:19 pm »
Right got my mfsw now need a controller. Which one do I need I read I can use 1K0 953 549 AK control module but isn't there different ones too. I have a high line speedometer with cruise control.
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
Re: Which control module for mfsw
« Reply #1 on: November 02, 2016, 02:09:16 pm »
http://wiki.ross-tech.com/wiki/index.php/Steering_Wheel_Control_Module_Versions
Any one that says highline will work.
You can get a CH one for 45 quid on ebay, Comes from china and takes 10 days but ive never had issues with them
Offline axsweb
« Reply #2 on: November 03, 2016, 08:22:45 pm »
Have you got a link to the one on eBay? Also what's with the different numbers on the high line ones do they have different features or something?
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #3 on: November 03, 2016, 09:33:55 pm »
Look at this on eBay  http://www.ebay.co.uk/itm/321428386324
Sent from my SM-G928F using Tapatalk
Offline mikezs
« Reply #4 on: November 04, 2016, 09:22:29 am »
These steering wheel controls do loads of stuff, but here's what you need to know for MFSW:
The highline ones are the only ones that support LIN (the communication from the MFSW) and the RED display on the clocks (mk5) is LIN 1.3 and the white display (mk6) is LIN 2.0. This is what makes the CH version good, because it supports both versions.
You can choose any highline LIN 1.3 module from the ross-tech page.
It'll need coding and the steering angle sensor sorting once it's installed. You dont need to take the steering wheel off to install it
Edit: You also need to check if you've got a steering angle sensor and get a controller to match that
« Last Edit: November 04, 2016, 09:26:36 am by mikezs »
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #5 on: November 04, 2016, 09:47:07 am »
^^ THIS.
It is easier if you remove the steering wheel because the T8 torx bit will be harder to get to if steering wheel still on.
YouTube mk5 golf multifunction steering wheel. You will see a video I made on how to swap it over.
Offline axsweb
« Reply #6 on: November 28, 2016, 12:59:57 pm »
Right orders the ch controller and fitted it. Only thing now is coding anyone know the coding for this? When I turned the engine on the speedo needles didn't move and no lights shown on the dash too. Also the steering wheel controls lights stayed on. Hopefully coding it should sort it out.
Offline mikezs
« Reply #7 on: November 28, 2016, 03:01:50 pm »
You need to code the module with VCDS before you can do anything. They can't code them before they send because they're quite specific to your model (DSG, stalks, steering angle, wheel, etc). I expect it's setup for a mk6 golf with DSG before sending to you.
Where abouts are you?
Offline axsweb
« Reply #8 on: November 29, 2016, 01:03:59 pm »
I'm in Manchester Ashton Under Lyne OL6 area
Offline mikezs
« Reply #9 on: November 29, 2016, 01:09:01 pm »
I'm in Essex, you might have to find someone local. There's a register for VCDS owners on the site somewhere
Offline axsweb
« Reply #10 on: November 29, 2016, 10:36:11 pm »
Right got my mate to code the wheel and having a problem. The left buttons works and the right buttons the menu one doesn't do anything. The other 3 buttons work tho. Is there something to get that button working too. I'm sat in my car with vagcom at the minute.
Vol up = Works great.
Vol Down = Works great.
Star = Mutes sound.
Phone = Opens Bluetooth on my head unit
Right buttons do the following:
Menu Button = does nothing.
Ok button = Works great.
Up arrow = Cicles up on the cluster displaying MPG etc.
Down arrow = Cicles down on the cluster displaying MPG etc.
« Last Edit: November 29, 2016, 11:23:21 pm by axsweb »
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #11 on: November 30, 2016, 08:33:43 am »
If you have a highline cluster, its supposed to toggle through the menus with that button. If its not working theb using vcds go into instruments, adaptation and do a reset on channel 0. Turn car off, lock it, leave for 15 minutes and then start  car again and it should work.
Offline mikezs
« Reply #12 on: November 30, 2016, 09:14:45 am »
Mine did the same thing when I first coded it. I just left it to the next day and it started working.
Another handy shortcut: If you're not on the vehicle info screen you can hold up arrow to go back to it. I quite often switch to radio by pressing menu, then quickly back to info by holding up.
Offline axsweb
« Reply #13 on: November 30, 2016, 12:29:15 pm »
I'll try that. I've got a high line cluster and can access the menu using her stalk on the right hand side.
Offline axsweb
« Reply #14 on: December 23, 2016, 09:22:58 am »
Right I've done this so far. Now two lights are showing
