Author Topic: Which control module for mfsw  (Read 13896 times)
Offline mikezs
Re: Which control module for mfsw
« Reply #15 on: December 23, 2016, 09:50:51 am »
Those are the lights you get when you disconnect the battery, just driving makes them clear normally.
If it doesn't clear you might have to do the steering angle adaption (like when you first installed the controller)
Offline axsweb
« Reply #16 on: January 02, 2017, 08:53:25 pm »
Sorted the lights out. All controls working okay just the stupid menu button not working.
Offline ducman77
  • -Given: 59
« Reply #17 on: January 02, 2017, 09:57:05 pm »
Just jumping in here to send a big shoutout to @RetroRaz  :happy2:
I used your YouTube video to great effect when I was retrofitting a MFSW to my MK5
Thanks a million for the video buddy :happy2:
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #18 on: January 03, 2017, 12:08:24 am »
No worries buddy. YouTube recently disabled the video due to some racism being thrown at me for no reason. But it can be enabled again.
Sent from my SM-G928F using Tapatalk
Offline Broomy
  • -Given: 18
« Reply #19 on: January 13, 2020, 04:08:18 pm »
I think I’ve figured out I need a ch module to match highline cluster, mfsw & cc as my AF module is midline. Do I need the separate harness? (5K0971584C)
Offline mikezs
« Reply #20 on: January 14, 2020, 02:19:21 pm »
You will if it didn't come with the MFSW and you don't have DSG
Offline Broomy
  • -Given: 18
« Reply #21 on: January 15, 2020, 09:04:02 am »
Perfect. Thanks a million  :happy2:
Offline Octoparrot
  • -Receive: 102
« Reply #22 on: January 15, 2020, 11:53:42 am »
I believe that part number is for the mark 6. The part you need is 1K0971584C.
Offline RobC
  • -Receive: 20
« Reply #23 on: January 16, 2020, 08:54:39 am »
It works in the Mk5 as well. Its essentially a cross over that supports both LIN 1.3 & 2.0 and so is used when retrofitting later steering wheels but believe it still works with the Mk5 MFSW etc.
http://wiki.ross-tech.com/wiki/index.php/Steering_Wheel_Control_Module_Versions
Rob
Offline mikezs
« Reply #24 on: January 16, 2020, 09:02:30 am »
Rob
It definitely does not fit, and I've got a mk6 harness if you'd like it for the cost of postage if you want to try it!
Offline RobC
  • -Receive: 20
« Reply #25 on: January 16, 2020, 09:12:49 am »
Rob
Apologies, I thought you were talking about the SWCM, not the harness. Ignore me!  :doh:
Offline mikezs
« Reply #26 on: January 16, 2020, 09:25:21 am »
Rob
Ah, yep. That CH module is the magic one that's cheap from china and supports highline mk5 and mk6. Defo need the Mk5 harness though, the connector plug for the MFSW controller doesn't quite reach!
