Author Topic: number plate type ? number plate surround delete? what's your setup?  (Read 5683 times)
Offline croak2012
  • My first Gti mk5
whats your setup?
I'm going to buy new grills for my front and also new number plates to freshen everything up.
I was thinking about getting rid of surround and getting some aluminium plates with magnets/suckers? anygood?
embossed or not?
or the clean plastic look with no eu badge/border etc and autohaus surround... ?
anybody seen/have those 3d gel number plates ? are they gimmicky or do they actually look stylish?
Offline Trow81
Re: number plate type ? number plate surround delete? what's your setup?
« Reply #1 on: November 03, 2016, 06:10:35 pm »
I have aluminium pressed plates and autohaus surround but only on the rear as I have a smooth front grille looks good imo. I have read that the gel plates don't last long and begin to peel but I've never used them myself tbh so can't really say
Offline grey golfster
  • -Given: 79
« Reply #2 on: November 03, 2016, 06:19:11 pm »
Agree, have seen the gel dome ones peeling.
Offline rashg60
  • -Receive: 41
« Reply #3 on: November 03, 2016, 08:47:29 pm »
You can't really go wrong with a set of aluminium pressed plates - they look clean and stylish.
I'm not a fan of the gel plates - look a little tacky in my opinion.
Previous motors (in order of succession since 1994):-
VW Golf MK2 GTi 8v
Peugeot 205 1.9 GTi
VW Corrado G60 Supercharged
Volvo C70 2.0 Turbo Convertible
Audi TT MK1 1.8T quattro (225)
Mercedes CLS 320 V6
Audi TT MK1 3.2 V6 Quattro
Audi A4 Convertible 1.8T Quattro
VW Golf MK5 GTi 2.0 Turbo
Offline Matto
  • -Receive: 116
« Reply #4 on: November 04, 2016, 02:31:24 am »
Personally I wouldn't bother with magnets again. I had them for a while when I had a smooth grill. The number plate was backed with felt to stop the magnets scratching the grill panel but because the felt is like a sponge, it held the water and corroded the magnets.
I then tried the suckers which worked for a while but needed super gluing to the number plate as they wouldn't hold. They just went hard and I came out to the number plate on the floor a few times.
I got fed up and went back to having the standard surround although shortening it down to suit my private plate.
« Last Edit: November 04, 2016, 02:33:19 am by Matto »
Offline croak2012
  • My first Gti mk5
« Reply #5 on: November 06, 2016, 01:15:33 pm »
how have you attached your front plate?
can you use double sided tape on alu plates?
thanks
Offline Trow81
« Reply #6 on: November 06, 2016, 01:20:51 pm »
Front plate is in the window or there is no point having a smooth grille will probably get a small plate and relocate at the front somewhere. Plate has been in the window for over a year and never been stopped
The rear plate surround can either be fixed on with number plate stickies few quid from Halfords or screwed into bumper
Offline croak2012
  • My first Gti mk5
« Reply #7 on: November 06, 2016, 03:07:50 pm »
OK thanks, pressed plates orderd.... I kin d of like a clean look-   does autohaus surround look  good ? everyone... don't want screw holes .... I would like a smooth grille but not sure I would be comfortable with plate on dash...
« Last Edit: November 06, 2016, 03:14:46 pm by croak2012 »
Offline Trow81
« Reply #8 on: November 07, 2016, 05:53:53 pm »
Surround looks good in the back I've stuck my in rather than screw but there will prob already be two screw hikes behind the plate when u remove it
Offline croak2012
  • My first Gti mk5
« Reply #9 on: November 11, 2016, 02:56:56 am »
damn ... my embossed aluminum plates have arrived but... they have a black border around then hmmm.... I will have to go with the border now as I can't send them back haha.... would the number plate surround cover the embossed border ?
Offline mr lobitos
« Reply #10 on: November 11, 2016, 05:59:08 am »
I've got a couple of surrounds sitting in the garage you can have for just  the price of the postage
Offline croak2012
  • My first Gti mk5
« Reply #11 on: November 11, 2016, 05:53:14 pm »
hey lobitos - I'm looking into autohaus ones but thanks!
surround on my plates :( maybe would look better with no surround at all ...
« Last Edit: November 11, 2016, 06:16:31 pm by croak2012 »
Offline Ashjstarr
« Reply #12 on: November 12, 2016, 09:09:18 pm »
I went with smoothed grille from ebay
Fits nicely but paint finish isnt great so will end up re-painting it in spring.
Also have ali pressed plates, they look awesome and ive put them on every car ive owned.
Ran the front one in the window for a while but got fed up of it rattling against the dash/windscreen so fixed it to the front with pads from halfords, still looks cleaner than the stock grille imo.
Offline croak2012
  • My first Gti mk5
« Reply #13 on: November 12, 2016, 09:16:08 pm »
just ordered a gt grille that has a surround -- but if it does not look good I will probably just do the same thing as you - buy a fresh grill and stick my ali plates with halfords pads... thanks
Offline Dave J
  • -Given: 45
  • -Receive: 63
« Reply #14 on: November 13, 2016, 05:11:42 pm »
Well I always thought I'd go with the magnets or suckers route on the front, and neither seemed ideal.
So I got a reflective sticker vinyl plate to go on my OEM US smoothed grille - just not sure if to do it, or fit the shortened hard plate with velco / tape. Both are 'technically' show plates, but have proper font, size, spacing, reflectiveness, postcode, etc. Would still ping ANPR cameras if car was stolen, etc. Just not sure if I want to do it now & keep the huuge OEM number plate plinth.
It would look so much cleaner without the plinth and original plate though...
Edition 30 - no. 1387
