Author Topic: Disconnecting the open bonnet sensor  (Read 7144 times)
Offline TheBALDpuma
« on: November 10, 2016, 03:55:41 pm »
Mine is broken, and I can't get it sorted until next week - tomorrow I've got to drive 200 miles down the A1 on wet, salty roads and I could really do with my screen washers!  Is disconnecting the sensor possible? Is it easy? Will it let me use my washers?
Offline TAPPY
  • -Receive: 56
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,103290.0.html
Re: Disconnecting the open bonnet sensor
« Reply #1 on: November 10, 2016, 04:02:56 pm »
Iirc if you disconnect it then it will still be on
Best way to find out is disconnect the plug and see if it goes out
« Last Edit: November 10, 2016, 04:14:44 pm by TAPPY »
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #2 on: November 10, 2016, 06:02:25 pm »
You may need to bridge the wire connection for it to work
Offline TheBALDpuma
« Reply #3 on: November 10, 2016, 06:21:56 pm »
How would I do that?  Can I just leave it like that for a week if it works?
Offline TAPPY
  • -Receive: 56
« Reply #4 on: November 10, 2016, 09:32:35 pm »
If you open the bonnet and look at the latch, follow the wire to a small plug on the front panel and pull the plug apart pressing on the tab. If it does make the bonnet open light go out and the wipers work then it will be fine to use for a week or so. If not try what r5gtt said and bridge the plug with say a paper clip or something like that
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #5 on: November 10, 2016, 09:43:35 pm »
It should make the wipers and washers work.
Offline TheBALDpuma
« Reply #6 on: November 11, 2016, 07:27:24 pm »
Thanks all. Unplugged and washers are working!
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #7 on: November 11, 2016, 08:43:43 pm »
Offline TAPPY
  • -Receive: 56
« Reply #8 on: November 11, 2016, 10:04:36 pm »
Perfect
