Author Topic: Auto Wipers, can i have them coded/turned off?  (Read 7990 times)
  • -Receive: 691
Re: Auto Wipers, can i have them coded/turned off?
« Reply #15 on: November 17, 2016, 07:23:41 pm »
OK, if you disable the rain sensor, flicking the stalk up 1 notch does one wipe and that's it.  Booooooo!
Offline AJP
  • -Given: 392
  • -Receive: 317
« Reply #16 on: November 17, 2016, 08:19:21 pm »
Well that's crap. But hats off for having a go for us!
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #17 on: November 17, 2016, 08:46:04 pm »
Bit of a strange question, but the auto wipers on my Mk5 GTI annoy the hell out of me! I'd rather use the intermittent wiper function with the variable rocker switch but it keeps being overridden by the auto sensor, is there a way to code the auto wipers off?
Cheers,
James
This functions an idiot  :doh:  they work when it's barely raining and don't work when it rains or work as high speed when it's just a light speckle
  • -Receive: 691
« Reply #18 on: November 18, 2016, 10:34:48 am »
No worries.  I was hopeful, but kind of suspected it wouldn't be that simple!
I can only guess the controller in the wiper motor is expecting a signal from the rain sensor, therefore I think the only way to do it would be to fit a wiper motor from a non-rain sensing car.  A 1.6 base model or something.  But I really can't see VW going to the trouble and expense of different motor modules for different cars.  They love their generic stuff!
Offline Facian
« Reply #19 on: November 18, 2016, 10:38:21 pm »
Ah that's unfortunate! I imagine it must be in the code somewhere else as like you say they likely wouldn't bother with a different wiper motor if they didn't even bother changing the stalk.
Offline 99hagued
« Reply #20 on: November 18, 2016, 11:46:10 pm »
Disconnect the sensor and it reverts back to the intermittent mode so you can use the rocker switch, I found this out a while back when I took my rear view mirror off.
Offline Lewo
« Reply #21 on: November 19, 2016, 01:38:14 pm »
How do you disconnect the sensor?
Offline 99hagued
« Reply #22 on: November 19, 2016, 03:26:23 pm »
Have to remove the plastics then slide the mirror off and the sensor is behind it. I know it's a bit of a ball ache, you would have thought it could be coded out.
Offline ChazGTI
« Reply #23 on: November 19, 2016, 11:36:52 pm »
Thanks for this! Mine have always driven me insane.
What's more annoying is when I've had cheap run about cars in the past that had better wiper settings, haha!
  • -Receive: 691
« Reply #24 on: November 21, 2016, 11:44:09 am »
Ah cool, a solution found!
Yeah that is really bizarre coding it out doesn't work, but disconnecting it does!   It must need coding out at a deeper level then, similar to when engine sensors are coded out.
I went through a spell of broken windscreens.  3 in 6 months.  Each and every time the fitter f'cked up the sensor pad that sticks to the glass, so my wipers have never been right since.  This is a good fix!
Does it take out the night sensor as well?  Not that I ever use that function, because erm, I was born with the gift of sight and know when it's dark!!
Offline 99hagued
« Reply #25 on: November 21, 2016, 06:24:35 pm »
Haha, to be honest mate I dunno coz I replaced my auto headlight switch with a chrome none auto one coz like you I can tell the difference between day and night. That and every time I drove under a tree the lights came on.
« Last Edit: November 21, 2016, 06:28:57 pm by 99hagued »
Offline ChazGTI
« Reply #26 on: November 24, 2016, 03:34:47 pm »
In the short time I tried having mine on auto, I noticed it would make people think I was flashing them down country lanes. Random cars started flashing me back...
Never again lol.
