Author Topic: Audi TTs 340mm front discs ???  (Read 1926 times)
Offline Johnsy
« on: November 13, 2016, 01:14:57 pm »
Am I correct saying the front discs from a Audi TTs are a direct fit to the front brakes on Mk2 Leon cupra ?
There the same calipers to my knowledge as R32/S3/TTs etc
Iv got the TTRS brembos on vagbrem carriers using the TTs discs, so there a good chance Iv confused the two upgrades .
Penny for your thoughts ???
Re: Audi TTs 340mm front discs ???
« Reply #1 on: November 13, 2016, 02:25:52 pm »
They are a direct replacement for the Cupra 345mm / S3 / R32 fronts, if I recall correctly.
They are notably lighter than the S3/R32/Cupra ones.
TTRS are 4 pots and as oem take a 370 rotor.  But with the correct hangar/ bracket you will be able to use the 340 (as you do)
I believe @xjay1337 also has this setup? Or @rich83
Offline Johnsy
« Reply #2 on: November 13, 2016, 02:55:03 pm »
Cheers , just making sure I'm not handing out duff advice
Offline skard
  • -Receive: 245
« Reply #3 on: November 13, 2016, 06:14:41 pm »
As above, you are thinking correctly.
I've had the ECP 340mm Pagid discs on my Tig with a standard 6R setup (R32/Cupra mk2 etc) for three years now, still no rust on the bells  :smiley:
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=qc77shatc13nf9t07s6g795hh5&/topic,19740.0.html
« Reply #4 on: November 13, 2016, 10:54:02 pm »
Not exactly sure what the question is but TTS 340mm discs work with R32/S3 calipers... so if the leon ones are the same as those then they will fit.
The brembo TTRS/DB9 calipers can be used with the 340mm discs if you have the correct brackets, which it sounds like you do.
