Author Topic: Lumpy idle, holding revs & hissing sound  (Read 3403 times)
Offline DM
« on: November 15, 2016, 10:50:56 am »
My wife's 2007 GTI has started idling really lumpy when warm, will sometimes randomly surge on revs, & when the engine is turned off I can here a hissing noise from the right hand side of the engine bay (As you look into the car standing at the front).
Any suggestions appreciated, as I'm a newbie here, more used to old aircooled VW's
Offline shoaybmakda
  • -Receive: 54
Re: Lumpy idle, holding revs & hissing sound
« Reply #1 on: November 18, 2016, 12:51:32 am »
Have you tried getting it scanned to see what faults come up?
Offline DM
« Reply #2 on: November 19, 2016, 06:44:23 pm »
Will it show faults without and dash warning lights on?
Offline ChazGTI
« Reply #3 on: November 19, 2016, 11:40:40 pm »
Yes it will. There will almost definitely be faults registered given the symptoms described.
Offline DM
« Reply #4 on: November 20, 2016, 06:34:59 pm »
Cheers guys, will get it into my local garage
Offline Jaks101
« Reply #5 on: December 04, 2016, 10:38:56 pm »
Check for damaged pipes to crank case and possibly a bad PCV valve (25£) part
Offline MIJ_JAGGER
  • -Given: 103
  • -Receive: 78
« Reply #6 on: December 04, 2016, 11:11:48 pm »
^^this x2
Happened on mine twice, first time round was the pcv, second time quite recently was the pipe on that connects from pcv to under the intake manifold, cheap and easy fix  :happy2:
Offline Saintsteve
  • -Given: 17
« Reply #7 on: December 06, 2016, 08:38:00 pm »
It could be the Diaphram that's split in the PCV valve assembly as it has a Pin hole in the side of it, which will Hiss air out of it and you will hear it especially when you shut the engine off.
HTH
Tornado Red Edition30 DSG Build Number 114
Atlantic Blue Mk7.5 GTE Advance
Follow Saintsteve330 on Instagram
