Author Topic: Noise from left side engine  (Read 21305 times)
Offline MartinGTI
Re: Noise from left side engine
« Reply #30 on: January 06, 2017, 03:48:06 pm »
Crikie! Mine is in garage today. Wont have any news until tomoro evening at least.
That's very strange they cant find it.... And there just giving up like that??
If you hear anything back from your email will you let us know? Cheers
Offline garrardrj
  • -Given: 76
  • -Receive: 42
« Reply #31 on: January 06, 2017, 03:57:54 pm »
When looking into the bonnet the chain is on the right of the engine bay together with the fuel pump. We discussed the issue at length, at the end if the conversation he said "is there really a problem"  the engine is reknowned for being noisy. So is there actually a problem ?
Offline garrardrj
  • -Given: 76
  • -Receive: 42
« Reply #32 on: January 06, 2017, 03:58:33 pm »
Yes will do.
Offline garrardrj
  • -Given: 76
  • -Receive: 42
« Reply #33 on: January 06, 2017, 03:59:53 pm »
Like I said mate. If its the left of the engine its not the chain or the tensioner.
If you sit on the drivers seat you can pretty much tell its from the left hand of the engine. Its likely to be the HPFP.
Is Cam Follower on the left or right of the engine bay? Can somebody confirm?
It is difficult to say which side the noise actually comes from tbh.
Offline MartinGTI
« Reply #34 on: January 06, 2017, 04:29:51 pm »
Well yes there is a problem firstly anyway. Iv had mine parked beside an identical car. No comparison. Mine is like a diesel! It should not sound like that.
In relation to which side its from the noise will travel along the camshaft so you will hear it on both sides.... Same as the noise travels up a screwdriver when pressed against the cam chain cover.
Offline garrardrj
  • -Given: 76
  • -Receive: 42
« Reply #35 on: January 06, 2017, 04:45:30 pm »
Was it alongside another 2006 GTI though? Didn't they change the engine in 2007 ?
Offline MartinGTI
« Reply #36 on: January 06, 2017, 04:50:47 pm »
Yep. 2005. And i owned a 2006 vrs before and it sounded nothing like this. In any event, mine didn't sound like this 3 months ago.... So it aint normal.
Offline f00glee
« Reply #37 on: January 06, 2017, 05:00:02 pm »
My two penneth..
I had exactly the same "chugging"/"diesel"/"marbles in a tin can" noise on my car, but only when warm. From cold start up it was quiet as a mouse. If you guys are experiencing the same noise, only when warm, I'd put a few quid on it being the same issue, but thats just my opinion!
After much research, watching videos similar to the ones here and reading posts similar to this one, I bit the bullet and changed the chain and tensioner (well, had it changed by a garage). Not because I knew for sure it was the culprit, but because I thought there was a good chance of it and if it was the chain/tensioner, I didnt want to leave them to get potentially worse. Also I figured If anyone was going to get as far as looking at these parts to see if they're failing (condition might not be easy to judge anyway - i.e. I'm told tensioner sits on a ratchet when engine off so difficult to gauge its condition), they may as well replace them whilst they're in there! My luck was in and now my car is quiet as hell (comparably, anyway) warm or cold.
Its a tricky one I know, there are also plenty of people who say their car has made the noise for ages and been fine, but I couldnt stand it!
Not sure if this post is helpful, just though I'd stick my oar in!  :signLOL:
Current:
Mk6 R, Tornado Red, 5-door, '13.
Previous:
Mk5 GTI, Tornado Red, 3-door, '06, R-tech Stage "1+"
Offline MartinGTI
« Reply #38 on: January 06, 2017, 05:09:39 pm »
Thanks for that. Im with you... Strongly think its chain and tensioner!
Offline MartinGTI
« Reply #39 on: January 06, 2017, 05:22:36 pm »
@ garrardrj. Did they change the chain and tensioner and noise is still there? Or just look at it?
Offline garrardrj
  • -Given: 76
  • -Receive: 42
« Reply #40 on: January 06, 2017, 07:14:43 pm »
They stripped it back and didn't change. They had quoted me £650 with some other work that needed doing. I paid £269. Not replaced and not really charged much at all bearing in mind they had it for 2 days trying to find the cause.
Offline MartinGTI
« Reply #41 on: January 06, 2017, 08:53:48 pm »
Ok thanks. In one way its a pity when they had it all stripped they didn't just replace the chain and tensioner. Think the two parts are only around £100.
I should have some news on mine tomoro evening, i hope!
Offline garrardrj
  • -Given: 76
  • -Receive: 42
« Reply #42 on: January 06, 2017, 09:30:32 pm »
I am sure the tensioner is over £200 isn't it ?
Offline MartinGTI
« Reply #43 on: January 06, 2017, 09:46:32 pm »
God no. The third part that most don't change is the cam chain adjuster. That's £270. Cant remember exactly but the other two, chain and tensioner can be got for close to £100 for both....
Offline v4rley
  • -Receive: 104
« Reply #44 on: January 06, 2017, 10:25:29 pm »
Tensioner is around £100 and chain £70 for genuine from the dealer
