Author Topic: Wheel bearing?  (Read 4501 times)
Offline S800BRN
  • -Receive: 27
Wheel bearing?
« on: November 19, 2016, 11:41:49 am »
I can't remember if I posted this problem here before or not...
Anyway I have a really irritating 'grumbling' noise in my Ed30 - sounds like it's coming from the wheels.
It's pretty constant, sounds the same in any gear, sounds the same with clutch in/out doesn't get worse or change noise when cornering.
I had it at a garage a few months ago - they could see nothing wrong with anything. No play in any of the wheels. They recommended I run it and see if it got worse.
No change in noise but it's still there and it's driving me nuts - was in for a service the last day so asked the garage to have a nose around again - same thing, they couldn't find anything.
I replaced all discs and pads to rule out a warped discs a few month back.
Any ideas or experience would be appreciated!
Re: Wheel bearing?
« Reply #1 on: November 19, 2016, 12:41:34 pm »
I just did the bearing on her altea. The noise before was unbearable at 40+
There wasn't any play in the wheel and looked in half decent condition when I took it off.
I only buy a cheap assembly on, which is against my nature but for the cost I can do it 3x over.
The noise didn't change when cornering that I noticed
Anyway, replacing it cured the noise.
Offline S800BRN
  • -Receive: 27
Re: Wheel bearing?
« Reply #2 on: November 19, 2016, 12:58:56 pm »
Cheers Mike. Funny you say that - 40 mph seems to be when mines noisiest too. You do both at the same time. Think I may do the same - just go ahead and replace the fronts.
Offline Lewo
Re: Wheel bearing?
« Reply #3 on: November 19, 2016, 01:33:19 pm »
Pretty sure I've got the same on my car.
Any idea on how much oem bearings are? I've seen a few on Ebay and the price seems to vary quite a bit.
Is there anyway of telling if you have got 30 or 32mm fitting before taking the old ones off?
Re: Wheel bearing?
« Reply #4 on: November 19, 2016, 01:47:47 pm »
Oem around £120. I could've got them for £85
The cheap non gen one I got was £35.  I had the 18mm dealer spline socket and 14mm dealer spline socket to the hub bolt and caliper hanger bolts, already.
Offline Lewo
Offline grey golfster
  • -Given: 79
Re: Wheel bearing?
« Reply #6 on: November 19, 2016, 03:19:23 pm »
As per their ad, try phoning to see what brand the bearings are, and perhaps to try gauge if likely gen european non-oem, or Chinese sh1t...or perhaps worse still Chinese fakes of european non- oem.
At this price, my bet would be Chinese, and so I would never knowingly fit, most  especially to a powerful front wheel drive car...
I'm no OEM only sort of bloke, but as far as I am concerened there's non-oem, and then there's some potentially dangerously nasty Chinese tat...
Pays your money etc...i might, perhaps, fit something like these to my £750 mk3 cabrio...all 70 hp of it!
Offline shoaybmakda
  • -Receive: 54
Re: Wheel bearing?
« Reply #7 on: November 19, 2016, 05:58:23 pm »
I just did my near side rear and the noise got loudest at 40mph. Was a grinding noise thought it was my tyres first then found out it was the bearing. Annoying to say the least!
Offline S800BRN
  • -Receive: 27
Re: Wheel bearing?
« Reply #8 on: November 19, 2016, 06:14:04 pm »
Thanks for the replies.
Thing is because none are obviously showing signs of wear/play I don't know where to start.
I'll maybe just change the front two then see how that works out...
Offline colesey
  • -Receive: 89
Re: Wheel bearing?
« Reply #9 on: November 19, 2016, 06:24:00 pm »
Have you checked your wheel alignment? That worked for me.
Offline S800BRN
  • -Receive: 27
Re: Wheel bearing?
« Reply #10 on: November 19, 2016, 06:33:32 pm »
My alignment was done probably around 9/10k miles ago (after I fitted the Eibachs) haven't hit any pot holes or changed anything suspension wise since.
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
  • K04 PLAY....ZOOM DIS!
Re: Wheel bearing?
« Reply #11 on: November 19, 2016, 06:38:46 pm »
My rear bearing hub began making noise...there wasn't any noticeable movement when I checked by rocking the wheel side to side or up and down. I replaced the hubs regardless and they were fixed. I did them myself, but would recommend using a tech for the front hubs if not secure/confident in your mechanical ability.
Online Andy
Re: Wheel bearing?
« Reply #12 on: November 19, 2016, 10:20:24 pm »
its usually a rear bearing on the mk5 i have found that needs replacing
Offline Lewo
Re: Wheel bearing?
« Reply #13 on: November 19, 2016, 10:34:53 pm »
Where did you get your bearings from Mike?
If motor factor are these from ECP ok for quality? http://www.eurocarparts.com/wheel-bearing-and-wheel-hub
« Last Edit: November 19, 2016, 10:53:07 pm by Lewo »
Re: Wheel bearing?
« Reply #14 on: November 19, 2016, 11:09:25 pm »
https://www.energizedcustoms.co.uk/shop/
Quality is okay.  If it gets noisy in 12 months I'll probably stick a genuine one on.
