Author Topic: TFSI cam follower  (Read 4003 times)
Offline GtiKris
TFSI cam follower
« on: November 19, 2016, 12:43:49 pm »
Hi people
Today was the day, when after weeks I have finally decided to change cam follower on my 07 Tornado.
Glad I did change it as it was badly worn... not sure how long would it last.
Must say it is a very easy job, took me 30 mins! Very pleased
GtiKris
Kris
Offline grey golfster
  • -Given: 79
Re: TFSI cam follower
« Reply #1 on: November 19, 2016, 03:21:32 pm »
That wear pattern looks weird to me?
Good job, well done!
Offline GtiKris
« Reply #2 on: November 19, 2016, 03:24:10 pm »
What do you mean by saying weird?
GtiKris
Kris
Offline 1.8T Chap
« Reply #3 on: November 19, 2016, 06:03:20 pm »
I've just done mine also, I lubed it up with some fresh oil prior to installing but it now sounds ticky more than before, any ideas?
Offline GtiKris
« Reply #4 on: November 19, 2016, 06:05:59 pm »
I got mine from vw dealer and I thought they come pre-lubed? Mine did not change the way it sounds at all...
GtiKris
Kris
Offline 1.8T Chap
« Reply #5 on: November 19, 2016, 06:26:57 pm »
Yeah mine was from dealer also they do come pre lubed as such but put a film of oil on it also to help, just sounds more tappy than it did before but followed instructions to the letter on replacement so not sure why
Offline doylebros
« Reply #6 on: November 19, 2016, 06:41:53 pm »
Mind that's not the normal wear pattern I've noticed either but it looks like you've caught it in time. :happy2:
Offline GtiKris
« Reply #7 on: November 19, 2016, 06:46:52 pm »
Yeah... did not had much life left me think
Any ideas as to why this pattern is not normal in your opinion?
GtiKris
Kris
Offline doylebros
« Reply #8 on: November 19, 2016, 07:02:55 pm »
GtiKris
Did you look at the cam-lobe for damage and scoring? It implies to me a bit of debris has been between the tappet and lobe causing that style of damage.
Offline GtiKris
« Reply #9 on: November 19, 2016, 07:06:34 pm »
No I did not look tbh... I will see if I can get it off again and check for wear. Thanks
GtiKris
Kris
Offline 1.8T Chap
« Reply #10 on: November 19, 2016, 07:08:49 pm »
Did yours have the banjo bolt type pump?
Offline GtiKris
« Reply #11 on: November 19, 2016, 07:12:31 pm »
Luckly no... it is 07 car so have the easier option
Kris
  • -Given: 79
« Reply #12 on: November 19, 2016, 07:19:34 pm »
GtiKris
+1.
I'm no expert, but that wear pattern is unusual, as i think you will find if you have a dig about on here.
As Doyle says, I think it might be worth having a look at the lobe. Easy-peasy now you're experienced!
Offline GtiKris
« Reply #13 on: November 19, 2016, 07:25:44 pm »
Thanks guys... will have another look. Hopefully it is not worn or damaged.
GtiKris
Kris
Offline 1.8T Chap
« Reply #14 on: November 19, 2016, 08:18:01 pm »
Did you prime your pump before starting? I.e turn the key a few times before starting or just started straight away after replacing?
