Author Topic: TFSI cam follower  (Read 3984 times)
Offline GtiKris
Re: TFSI cam follower
« Reply #15 on: November 19, 2016, 08:21:00 pm »
Opened drivers door, as this prime pump and then turned key few times as well. Car started normally, no chokes etc
GtiKris
Kris
Offline Madone
  • -Receive: 27
« Reply #16 on: November 20, 2016, 12:27:31 pm »
Yeah... did not had much life left me think
Any ideas as to why this pattern is not normal in your opinion?
GtiKris
The follower should rotate as it runs on the cam, the cam profile isn't flat so it causes the follower to rotate. The wear pattern should be circular on the follower. Something wrong with yours, either the cam is damaged or the follower couldn't rotate for some reason. Very odd
