Author Topic: RNS510 Buttons  (Read 17821 times)
Offline V6nutter
  • -Given: 17
RNS510 Buttons
« on: November 27, 2016, 07:46:41 am »
Would anyone know why the buttons don't light up?
Offline V6nutter
  • -Given: 17
Re: RNS510 Buttons
« Reply #1 on: November 27, 2016, 09:40:58 am »
Ive pulled the CAN information from the unit
Speed Signal 0km/h
CAN Reversing off
KL15 on
KL58 d 94%
S-Kontact on
Mute bit off
Analog mute off
Mute Value 0
Do these look ok?
Offline V6nutter
  • -Given: 17
Re: RNS510 Buttons
« Reply #2 on: November 28, 2016, 04:00:35 pm »
Just been quoted £700 to fix the unit. Can't believe nobody else on here has had this issue.
Offline Pashka
Re: RNS510 Buttons
« Reply #3 on: November 28, 2016, 04:02:47 pm »
What is the unit version and how did it happen? Just sudenly stopped to work? There is no part in the unit for 700.
06 1.9 TDI Owner. Retrofits: Bixenons, Drls, Full GT/GTI exterior, RNS510+MDI+Premium Bluetooth+RVC+OPS, Full Fis, MFSW, Cruise control, TPMS, Polar Fis, Boot pop up and more.. :)
Coding, diagnostic and retrofits in Leeds
Pre coded Can Gateways for battery drain issues with RNS510 and similar headunits
Premium Bluetooth modules/kit
RNS510 Service - codes, maps/firmware updates
Latest V8 West EU maps update service for RNS315
Offline V6nutter
  • -Given: 17
Re: RNS510 Buttons
« Reply #4 on: November 28, 2016, 04:04:51 pm »
These are the details.
Was told it had to be sent to France...
Offline Pashka
Re: RNS510 Buttons
« Reply #5 on: November 28, 2016, 04:46:42 pm »
Is it star button or speaker on the top? next to the injection button? and how did it happen? Also, do you have vcds or similar tool to check can connection? It uses different can connection and for example if you have polar fis or other thing that uses the same can connection line and if you unplug it, the cans will not work, illumination aswell. Secondly, can controller is the part of the main board, but  I haven't seen any unit that would die naturally, it is possible after accident or water damage. The main board is around 200 plus labour.
If you are near leeds, I could put the unit on the desk and using special software do the diagnostic, check illumination etc.
Offline V6nutter
  • -Given: 17
Re: RNS510 Buttons
« Reply #6 on: November 28, 2016, 05:10:40 pm »
It has the speaker icon. So go figure this. I just go to the car and unlock it all the lights come on including the lights on the RNS. However they go off when you turn ignition on. I'll get a video up if I can. Thanks for your replies, I'm in Nottingham so not a million miles away.
Offline V6nutter
  • -Given: 17
Re: RNS510 Buttons
« Reply #7 on: November 28, 2016, 05:36:02 pm »
Check out this video..
If you can help I'd be most grateful
Offline V6nutter
  • -Given: 17
Re: RNS510 Buttons
« Reply #8 on: November 28, 2016, 08:16:40 pm »
So now I've been told SW4020 is not compatible with H03 and could cause damage to the LCD board I've been told to downgrade to 3810.
Offline skard
  • -Receive: 245
Re: RNS510 Buttons
« Reply #9 on: November 28, 2016, 08:24:38 pm »
I had a modded 4020 with an H03 unit and an A hardware.
I would revert the firmware to try, but if you go older than 3800 you will repartition the hard drive and lose your maps
Ninja
Re: RNS510 Buttons
« Reply #10 on: November 28, 2016, 08:37:18 pm »
Offline V6nutter
  • -Given: 17
Re: RNS510 Buttons
« Reply #11 on: November 28, 2016, 08:49:54 pm »
I will use 3810 - I think I have D Hardware (1T0035680D) H03 unit...
Do you know of a link where I can download the firmware?
Offline skard
  • -Receive: 245
Re: RNS510 Buttons
« Reply #12 on: November 28, 2016, 08:53:39 pm »
I bet you have an A unit. When the firmware gets updated, it falsely updates the unit part number you see. It'll be on a sticker on the side, but you would have to remove it. A true D would have a star at the top right.
I haven't had one of these for a couple of years now, but I will look for you
Offline V6nutter
  • -Given: 17
Re: RNS510 Buttons
« Reply #13 on: November 28, 2016, 08:56:37 pm »
It's the one with the speaker and an i
Offline V6nutter
  • -Given: 17
Re: RNS510 Buttons
« Reply #14 on: November 28, 2016, 08:58:25 pm »
Ive found these links...
Volkswagen RNS 510 Firmware Upgrade version 3810 / 3812 / 3814 / 3816 / 3818 – Details
Update
Download Location 1: RNS_510_FW_3810_update.rar – 485.37MB
(RNS_510_FW_3810_update.nrg – 671,329KB
Update Modified (Regensburg syndrome, MP3 VBR Resume for revision A, B and C head units)
Download Location 1: RNS_510_FW_3810_update_modified.rar – 485.45MB
(RNS_510_FW_3810_update_modified.iso – 671,670KB)
Download Location 2: 3810a_noru.rar – 485.43MB
Which one would I need?
